Comparing tires for my C63
***Updated list, removed the Michelin Pilot Sport
Looking to possibly switch out my tires and this is what I've come up with. I have 18" wheels. Looking for good all season tires. Any suggestions?
- Continental ExtremeContact DWS06
- Continental ControlContact Sport AS
- Michelin Pilot Sport A/S 3 Plus
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
I am partial to the Michelin pilot super sport but it is summer only and tread life is pretty short, but they are not all season so you should take them off your list.
C63 coupe, Z3M Roadster garage queen
valid point, maybe I should just be looking at summer tires. In that case the Pilot Sports should probably be back on the list. haha
Generally 45F is the limit for summers, if you don't have to drive at temps lower than that or can mostly avoid it then you can get away with summers, you will die on snow and ice though on PSS's.
The issue with all season is they are a compromise, so not as good as summer or snow tires, if you like to drive a bit aggressively, the summers will provide a quite a bit more grip than all seasons when the temp is about 45, below that the all seasons will be better, snow tires probably make no sense. Good all seasons will probably be 80-90% performance of summers when warm, so just depends on your driving style and how often it is cold. A lot of the manufacturers will not warranty summers if you drive under 45F and they chunk as the rubber gets very hard when cold.
The Conti ExtremeContact's are good tires, so are Michelin. You really won't notice a difference between the two, or most all season tires, on this car. As others have said, you really are buying the wrong tire. Hell, I had a summer tire on a 1 series through a winter in NY. Wasn't the smartest idea, but never wrecked. And that's in NY... You're in Texas...
By buying an all season tire you are sacrificing a great deal of performance, which is what that car is designed for, for the handful of days you'd have to just slow down a tad and take it easy. You're setting the car up for 10 days out of the year and not the other 350.
In my opinion you removed your best option from the list - Michelin Pilot Super Sport.
Or - Run an all season through the cooler months but put on super sports (or some summer tire) when it's warm.
I never had any issues with the Super Sports in cold dry weather either despite people that want you to think they throw off frozen chunks of rubber if you drive on them below 40F (definitely would not try them on snow).
For you, I'd consider the Continental ExtremeContact DW. Much better tread life than the PSS. You don't need a tire that can handle light snow in Texas.
Always great to see this tired old line five times in any thread where someone is considering all seasons....most cars on the road are on all seasons and I doubt Super Sports are making your commute in traffic that much faster.
Oh and the "all seasons" that provide a false sense of security are safer/faster? Tests have shown that all seasons perform nearly the same as summer tires in cold or winter conditions. So sacrificing dry performance for no reason makes no sense to me. And PSS are great for commuting since they last forever. My rears lasted 16k including a couple burnouts and quite a bit of hard driving around town.
I lived in Dallas for 30 years so I know the weather pattern you are dealing with.
9/10's of the time you'll be okay with a summer tire. I ran MPSS only for the first couple of years of owning the C63. Great tire wet/dry/warm, but absolutely horrible in the occasional Dallas snow. I experimented in the snow once and was defeated by a slight incline.
I had my daughter come get me in my other car that had Pirelli PZero Nero M+S. They were great all around. That car didn't have the power of an AMG but I sure cornered hard on those Pirelli's and they never broke loose. I kept putting set after set on that car for nearly 10 years.
C63 amg Custom 67 Camaro GLK 350 4matic 2017 AMG GTS
Michelin Pilot Super Sport are the best All season tires for this car bottom line.
But it all depends what you want and need out of the tire. The Conti extreme is only ok. The Super sport is by far the better all around tire you will find right now for this car in my opinion.
Yep I agree on Pirelli p zero I have tried
Conti extreme , sport , ran p zero on my rs6 they are awesome on my ecu tuned only c63 best grip from launch I have ever had in this car ... rears lasting around 3-4,000 klms , getting 3 -4 rear sets to every front set which is nice for a change 245/265 respectively
Do all seasons work? Yes. Will you still out perform most other cars on the road? Yes. But you're leaving a TON of car out of the picture by settling on all seasons. Tires are what contact the road, they are everything, and I've come to learn that by making the switch to the high end tires and spending the extra couple hundred bucks. Always worth every extra penny.
Also (not you jones) but MPSS are not all season tires. OP had this and corrected it. But others have confused MPSS to be all seasons which they are not. They are a summer tire.
At the end of the day, it just bugs me that people skimp out getting the proper equipment for their car and get positive reinforcement from others to cut corners. Then half the time people offload the car with budget parts, call them OEM/New/Best, and they become the new owners problem.
OP - Get yourself the continental DWS. Those will work just fine and be everything and them some for your commute / driving in the cooler months for Texas. But do yourself a favor and put the pennies away until we warm back up and get yourself on a set of Super Sports. Then just swap as the seasons change. You'll get the best of all worlds doing that.
I used my ex-wife's Challenger SRT 6 speed on Blizzaks in the snow. Most fun snow car ever. Never got stuck even in 9 inches at one point. Drift at will. I think the C63 would be fun in the snow as long as you have an LSD and snow tires
I would never use my C63 in the snow. Too much torque. You can drift an 80's Toyota in the snow.
By the sounds of it, the OP isn't going to track his car so the Continentals may be fine.
Thanks for input everyone.
So I've made the decision to get the Michelin PSSs. As stated by multiple users on here, 9/10 times I won't require winter/all season tires around Dallas. In the case, that it does snow here, most of Dallas shuts down anyway.. haha.
But I have other cars, with more capable tires, so I probably won't take the C63 out in the snow anyway.
2012 C63, Porsche 911 C2, 2000 Ford Ranger, HD DynaLow
Hancooks
Yeah, an entire shift in focus. For a number of years I raced on Hancooks and Coopers (spec tires) in F1600, F2000, ProMazda, etc. They were excellent, so I put Hancooks on my Porsche CS, and they were in turn excellent, and far less expensive than Michelins, Pirellis, Continentals, etc. Has anyone tried them? And yes, the C63 has noticeably more torque that my race cars, but the Hancooks and Coopers gripped remarkably well, were reliable in taking a consistent set, etc. Any thoughts?
