C63 AMG (W204) 2008 - 2015
Multiple Cylinder Misfires
Old Jan 26, 2017 | 04:42 PM
MTV10's Avatar
E55 AMG & C63 AMG
For the past month or so, intermittently been getting slight misfires at random. Happens when I first start the car and for 5-10 seconds after I drive off. Once every 10 starts. Checked for codes... nothing.
Today, slightly rough idle after starting the car. Felt the car misfiring, then it started misfiring pretty bad - Flashing CEL and whatnot. Stopped the car... restarted it. Still misfiring, read the codes and cleared them and the car slowly started idling normally after a few minutes.
Drove off without issue....
Below are the codes the car threw. Misfires in 3 cylinders. Plugs were changed 2 months ago. Could it be coilpacks?
Old Jan 26, 2017 | 04:48 PM
SuperFastYo's Avatar
C63 AMG - LSD
best way to find out is to move the coilpack to a cylinder that hasnt misfired. If it misfires in that cylinder then its a coilpack
Old Jan 26, 2017 | 05:19 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I would put money on an air leak, or potentially primary O2.
Very rare for a coil pack to work intermittently, even more rare (very very very rare maybe?) for multiple coil packs to work intermittently.
Old Jan 26, 2017 | 05:55 PM
w204nyc's Avatar
2017 C63S coupe '09 C63, '15 Durango RT, '14 Jeep SRT8
Originally Posted by Jasonoff
I would put money on an air leak, or potentially primary O2. Very rare for a coil pack to work intermittently, even more rare (very very very rare maybe?) for multiple coil packs to work intermittently.
Plus 1. Just had this happen and it was o2 sensor
Old Jan 26, 2017 | 07:51 PM
faz492's Avatar
e63 amg w212 6.3
had this issue recently fixed, coils. try what SuperFastYo said.
Old Jan 27, 2017 | 09:28 AM
MTV10's Avatar
E55 AMG & C63 AMG
Guys, I'm leaning towards primary O2. The fact that it is intermittent like that and the P2540 code lead me to believe it's O2 related. Also I highly doubt that multiple coilpacks will go bad all at once.
Old Jan 27, 2017 | 09:46 AM
skratch77's Avatar
2005 E55
make sure plugs are torqued right.they can get loose in there also
Old Jan 27, 2017 | 02:18 PM
jptaylor's Avatar
W213 E63S Wagon, W204 C63 P30(RIP), WK1 Grand Cherokee SRT8(RIP)
the 1st thing you need to do is ACTUALLY have your codes read....what you posted is the most generic OBD display possible....that is what you get from your general purpose scan tool and really tells you nothing more than you have an issue, which you already knew to begin with!!!!
either have a dealer scan it or grab a bluetooth ELM327 obd dongle and the pro version of Carly on apple or android and let the car tell you EXACTLY what is wrong with it...you will be amazed at the detailed diagnosis your car's ecm is capable of providing you
Old Jan 27, 2017 | 02:49 PM
PJmak's Avatar
I had this happen on my car which is a m113 motor. It was a fuel issue.
Car was showing over one qt but it had actually ran out of fuel.(bad sensor)
Make sure you check if you are getting fuel to the motor too I guess
