Alignment problems and steering wheel off center
#51
^I believe he has coilovers installed at shop 1, no alignment.
Then blowout.
Then went to shop 2 for an alignment and the bad alignment is what they sent him home with.
Then he either went back to the shop 1 that installed coilovers or a different shop for that last alignment which was better.
At least that's how I'm following this
Then blowout.
Shop 1: Did my install of coils and the better alignment
Shop 2: Did the FIRST AND BAD alignment and told me something is bad, sent me home with negative 3.7 camber.
I called the owner of shop 2. He said he himself had a C63 before and believes the coilover install shop adjusted the control arm bolts to make the camber go in spec, but it will be off again when I hit a bump. He claims the camber bolts have a lock or a nut that keeps them from slipping and that the way they adjusted the current bolts is bad. Basically he was avoiding blame.
He said he would offer me 25%-40% off next time lol. It sucks that this was the only time I didn't pay with my AMEX and used cash as AMEX is good about these kind of things. My fiancee is more of the arguing, fighting to get money back type.....I simply accept it and move on. I won't be going back. RCT Performance avoid them.
#52
We "technically" have no camber adjustment in the front. However, you can shave off the tabs (I think they call them crash tabs or something in the WIS) to achieve some adjustment. They are there to adjust camber if for some reason you wreck your car and the camber is out afterwards. You can see them in the below pictures, the red lines in the 2nd pic is what you would remove to make it flat.
Removing the tabs gives the LCA some wiggle room which allows for some camber adjustment. It's a "free" mod for those who are lowered looking to remove some negative camber.
Given how much you were lowered, the -3.7° from that 2nd shop who did your alignment was physically impossible on a C63 that has not been damaged. Even if those tabs were shaved and they had the LCA moved outward as far as it could go there's still no way you could get that much negative camber.
There was also no way to botch the coilover install to affect the camber like that either. This is why a coupe of us immediately assumed something was damaged when, in reality, it was just a screw up by the 2nd shop mounting/adjusting the alignment machine sensors.
Lastly, if you look at the left and right front camber delta between the two alignments, it's identical. You added 1.5° of camber to the left and removed 1.5° on the right. Since you have no camber adjustment this leads me to believe shop #2 didn't install the sensors properly or screwed up with the calibration. Shop #1 also reduced your caster on the left side which will helped prevent your car from pulling to the right. On top of that, they did make your rear a little worse, they increased your thrust angle by changing the rear toe. You may notice that under hard acceleration btw.
Either way, glad you're sorted now, don't worry about the rear. It's not out enough to be concerned about.
#53
SPONSOR
#54
Now, if he wants less camber to help with some tire wear your products would be right up his alley.
