265s up front?
265s up front?
Thought this would be asked before, but search came up with nothing. Does anyone run or have tried running 265s up front? Planning to get a set of PS4S, wondering if anyone manager to squeeze that extra 10mm in.
Are you on OEM wheels? I wouldn't run a 265 on an 8 inch wide wheel. You'll bulge quite a bit and sacrifice performance in corners because the tire will want to mush one way or the other.
You're also on coilovers and a widebody it appears.
I would max it out at 255.
Perhaps I should ask, why? Can't find the PS4S in a smaller size?
No definitely not on oems. Rims are 19x9 et 35, 19x11 et 16. Since I will be running either 305 or 325 in the rear I am generally curious if anyone has done 265s for better grip, since I've never seen anyone talk about it.
Received 2,835 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Yeah you can do 265/30 on stock front fenders with wider rims depending on offset. Actually fits better than the 255/35, which can slightly rub at full lock because of the slight height difference (26" vs 25.3"). I was running a 20mm spacer when I had my 245's with plenty of clearance.
http://www.tirerack.com/tires/tires....Pilot+Sport+4S
But ps4s only come in 305 (or 325)/30/19. Wouldn't that trip the ABS issue since .6% over 3%.
Stock 18s and Optional 19s are both 8" front and 9" rear so you run out of rim width before rubbing issues at stock height sadly.
I think BLKROKT and Gzim both fit 285s without rubbing on aftermarket 19s
