C63 AMG (W204) 2008 - 2015
Help Board ! Engine noise at startup !
Old Feb 10, 2017 | 10:07 AM
Kamal63's Avatar
Mercedes-Benz W211 E 6.3 AMG
Hello friend! Can you help me with the Council , you have a lot of experience and lot of knowledge unlike me. The situation is the following : when engine start , cold engine and hot start , sometimes the sound of the engine scares me , look at the link it looks like such a sound! What could be the reason? ( the mileage of the car is 20,000 miles , 2008 year )
Old Feb 10, 2017 | 11:00 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
The title of your video is the problem.
Old Feb 10, 2017 | 11:58 AM
AMGonFire's Avatar
2012 c63 AMG, 2011 GLK 350, 2019 GLS 450
Lots of people posting on this. I have posted on it multiple times check my history. My car still does it after the dealer replaced the cam adjusters. The dealer told me it's how they are after going to multiple dealers. I didn't believe them till they showed 3 diff cars one almost brand new and two customer cars that made the exact same noise. It's been 2 years with the noise and guess what car runs fantastic. It has to do with oil drain down vs an actual problem with adjuster. Unfortunately it's a design flaw. I bet you once you start it and it makes the noise you let it run for a minute. Shut the car off start it immediately again it will not make the noise. If it was truly broken it would make the noise every time. Regardless of oil in the unit or not. Some truly do break but they are typically constantly making noise they don't stop. Some will say theirs was fixed after repair I truly don't think so though mine wasn't.
Old Feb 10, 2017 | 12:10 PM
skratch77's Avatar
2005 E55
run 5w40 oil on next change
Old Feb 10, 2017 | 12:31 PM
Merc63's Avatar
C63 AMG
0w40 is way too thin, it's like water. Use above.
If it's not cam adjusters it's the lifters bleeding down. You can replace them with the sls lifters.
I've been using shell rotella T6 5w40 and no noise on startup now. It's gasoline engine rated.
Old Feb 10, 2017 | 02:02 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I've had zero issues with 0W40 M1 euro going on 5 years now. Buckets and cams were absolutely fine as well.
That ratcheting sound the OP has is most likely the adjuster. The lifter sound is not as sharp. Has a thicker cold weight helped others with the adjuster problem?
Old Feb 10, 2017 | 02:08 PM
skratch77's Avatar
2005 E55
I'm done with 0w40 m1 the dealer had my car for over a month and changed the whole top end.valves,lifter,cam,adjusters etc 2 months later same freaking noise.
swapped to 5w40 and never once heard the noise after.like many have said m1 is way to thin.
Old Feb 10, 2017 | 02:17 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Interesting. I wonder what the tolerances are in the adjusters.
Old Feb 10, 2017 | 02:43 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
While the M1 0w-40 is a better formulation than their 5w-40, I've been running the latter for 6 months (no track use, mostly storage) and my engine definitely sounds better.
I'll probably switch to the Rotella T6 5w-40 for track season
Old Feb 10, 2017 | 05:15 PM
Kamal63's Avatar
Today the dealer made a diagnosis of the engine , and found stored P0740 error! Wrong position of camshaft !
Old Feb 10, 2017 | 05:34 PM
Kamal63's Avatar
maybe this sound will disappear! if replace the camshaft sensor . ?
Old Feb 10, 2017 | 10:02 PM
LondonFOB's Avatar
W204
Did anyone play with your camshaft ? Why would it trigger ?
Maybe a new sensor would help
Old Feb 10, 2017 | 10:26 PM
minchu0647's Avatar
c63 amg
I think i have the same problem here. Can anyone confirm that dealership will replace the lifter with SLS parts for free under warranty? And I am going to track day in mid March, is it safe for the car? thanks!
Old Feb 11, 2017 | 02:28 AM
Kamal63's Avatar
reason think , not is the tappets , I observed , even if the engine is warmed up with a temperature of 100 ' C .! then switch off the engine for 20 minutes,and again start the engine , the sound can be repeated .
Old Feb 11, 2017 | 09:23 AM
BLKROKT's Avatar
Dude, just bring your car to the dealer or specialist. You don't sound like you should be trying to guess what the problem is.
Old Feb 11, 2017 | 08:27 PM
CarHopper's Avatar
E63S | X5
I don't get this guy. He starts two threads on the same thing after replying in the first one.
And then goes back into the first thread and edits all of his posts basically retracting and changing everything...
I'm genuinely at a loss.
Old Feb 11, 2017 | 09:18 PM
BLKROKT's Avatar
It's just the norm here these days man. Tempted to get back into a Porsche just for the more intelligible forum discussion.
Old Feb 11, 2017 | 09:23 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
What did you call me?
Old Feb 11, 2017 | 09:37 PM
BLKROKT's Avatar
Old Feb 12, 2017 | 09:25 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
As a kid I always wanted one of those houses with the hidden passage ways in the walls.
Old Feb 12, 2017 | 02:39 PM
Kamal63's Avatar
: Тема:
Old Feb 12, 2017 | 02:40 PM
Kamal63's Avatar
Dude . If I launch two threads on the same topic , so it should be there !not all who have a C class go to the topic where we discuss E class !
Old Feb 12, 2017 | 02:49 PM
chrisridebike8's Avatar
'10 C63
No. You made 2 in the W204 C63 section.
Old Feb 12, 2017 | 03:31 PM
ENV²'s Avatar
2001 Porsche 911 Turbo (heavily modified)
This. Liquimoly is what I switched to. Perfection
Old Feb 12, 2017 | 04:40 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
https://mbworld.org/forums/c63-amg-w...ml#post7054347 Someone doesn't know how to komputer....
