C63 M156 ticking noise
#101
Thanks for your answers.
I would ask a AMG Performance Center, instead of a normal Mercedes dealer.
Also I get another C63 for some coding stuff next week and can compare the engine sound.
#102
getting mine on friday
Buying a 2012 and I heard the tiking noise as well, just afraid and a bit worried if I have to fix it... don't like to hear any kind of unormal noises. Will Check again when the car is warmed up.
#104
#105
Should I get those extend warranty offered by the dealers ??(non Mercedes dealer) ($3.900) 3 years 40k, cover motor, cylinder block, cylinder head, pistons, valves, seals, gaskets, transmission, transfer case, drive axle just listed fews.
what you guys think?
thank you
trying to up load a video with the tick noise.
thank you
#109
Wow, thank you very much guys, Just took 1 ton of wheight out my head..... the last thing when you buy a used car is that something can be wrong with the engine...
I really appreciate all your inputs, that make me feel much better about my purchase.
thanks
thanks
#112
Now I have to go listen!!
#113
It´s the bad sound quailty.
I found another video:
https://www.youtube.com/watch?v=O-qrwORSiMg
That is exaclty what my C63 is doing.
For me that are 99% the Lifters.
But they are all new...
#114
Was it making noises on hot restarts or on cold starts? My car makes that exact same noise, but only when the car temps are hot (235-245) and only when I restart the car. I have all brand new camshafts, cam adjustors and lifters. This is frustrating.
PP-PRO_C63 (08-13-2023)
#115
Hello guys,
i´m writting from Germany.
The Dealer said to me my "noise" is normal, but i think this is bull****.
(Other M156 are ways quieter).
My Problem:
I got a ticking/ tapping noise.
It follows the rpm.
I think it is also louder at higher oil temp. (but I can hear it at any oil temp.)
Some recording:
https://www.youtube.com/watch?v=RaBq2g63-S4
https://youtu.be/aBPszUjGCxg
I replaced all head bolts and also all lifters.
The Cam Adjusters are locking, so i think they are not damaged (has already the last available partnumber).
Some guys told me that this problem could be the heads itself (oil supply to the lifters cracked or blocked).
Oil pressure is around 1,5 Bar at idle, and 4.5-4.8 Bar at 3000 rpm
Can anyone help?
Im not motivated, removing the heads again
My Problem:
It follows the rpm.
Some recording:
Can anyone help?
Hey man, i know this is an old post, but did you ever find a solution? New cams?
