C63 AMG (W204) 2008 - 2015
another tire question
Old 02-24-2017, 05:01 PM
bentz69's Avatar
'16 CLS63S
Had the car at the stereo shop and unfortunatly they somehow got a screw stuck right in the corner of the tire near the sidewall on the driverside rear. They agreed to replace the tire but I have a few options now
507 19" wheels with stock conti extreme tires. 8/32's remaining on the fronts and 6/32's remaining on the rears. Evenutally Ill migrate to the new michelin ps4's but for now Im just going to replace the 2 rears with conti extremes.
Various sizes of the conti's are on sale on tirerack (255/30/19 is only 123$). After reading a bunch of tire posts here, I see no problem with using a 275 tire on the stock 19" 507 wheel which is probably the route im going. Maybe even a 285 but I dont know yet.
Question is, since New York roads are the absolute worst with potholes, would adding some more sidewall (either a 35 or even 40 series) tire pose a problem with a 275 tire? Does a 285/35/19 rub?
Old 02-24-2017, 05:05 PM
Jasonoff's Avatar
Received 1,580 Likes on 931 Posts
2010 C63 AMG
Yes, it can mess up the ESP system. Stick with the correct OD, 275/30-19 if you want to go with a 275.
Old 02-24-2017, 05:06 PM
chrisridebike8's Avatar
'10 C63
Yes. Changing overall diameter of the tire is no bueno. I would not do a 35 or 40 series tire u less you want to upset the ABS and ESC. I think you should be fine with a 275/30-19 but not upping the aspect.
Old 02-24-2017, 06:46 PM
bentz69's Avatar
'16 CLS63S
That settles it. Thanks
