C63 AMG (W204) 2008 - 2015
Michelin Pss rotation
Old Feb 26, 2017 | 05:27 AM
Rick X Joaquim's Avatar
C63
Has anyone tried to rotate or swap tires, for the michelin pss?
What i mean is , dismout the tire and swap left to right, without changing direction. This would put side out of the tire into inside.
The reason is, i dont see a benifit if you swap the tire and change the direction. The inner side of the tire are still going be wear more.
Old Feb 26, 2017 | 09:57 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Don't they have an "outside" sidewall? If so, you can't swap them.
Old Feb 26, 2017 | 10:19 AM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
PSS should be labelled outside, so you can just swap them left to right as they are non directional, but it really buys you nothing as the inside will still wear more quickly - on my X5 I used to do it as they cupped running in one direction all the time, so switching them left to right and back every 3k stopped the cupping and noise the cupping caused, but otherwise no real reason to do it.
Old Feb 26, 2017 | 11:06 AM
chrisridebike8's Avatar
'10 C63
You can't do that. The belts start to set when used in a certain direction and swapping direction of rotation, especially in a high hp car can make them blowout.
Old Feb 26, 2017 | 12:04 PM
Dogtag114's Avatar
2009 c63
so.. another age old debate on rotation...
with my winter setup, 4 square, when I rotate, should I keep the left on left and just rotate back to front?
Old Feb 26, 2017 | 12:32 PM
'10 C63
Yeah. That's what I would do with a square winter setup
Old Feb 26, 2017 | 01:14 PM
Top Answer: 1
This is pure internet lore (or you are mixing this up with directional tires), find me a tire manufacturer that tells you not to do this, Michelin does not. If tires are a non directional square setup, the standard tire rotation in fact does exactly this where the rears move forward and the fronts move to the opposite side rears.
With a non square setup, right left rotation of non directional tires is the recommendation.
https://www.tirerack.com/wheels/tech....jsp?techid=43
Stop making stuff up - it is fine to rotate right to left.
Old Feb 26, 2017 | 01:25 PM
'10 C63
After looking into it more, it appears I have passed on an old wives tale. Thanks for the info.
Old Feb 26, 2017 | 01:40 PM
Top Answer: 1
No worries, there may be an argument about if it really makes any sense to do it however, maybe if you have an open diff and are wearing one side more than the other it is worth doing, otherwise, probably not really worth doing in a staggered setup.
Old Feb 26, 2017 | 02:40 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
My rears don't last long enough to give a sh¡t about rotating lol.
Old Mar 1, 2017 | 12:05 AM
QWKSNKE's Avatar
09 Carrera S, , 03 F250 CC FX4
No doubt. I'm lucky if my PSS'S make it to 4500 miles
Old Mar 1, 2017 | 12:35 AM
ItalianJoe1's Avatar
2003 CL 600
Yeah left to right isn't an issue, unless the tires are very old. I've had cars that had tires run the same way for several years, then got cross rotated and failed very quickly, but it's uncommon at best, only going to happen to old tires that have been run for their entire life one way, and highly unlikely to happen on a high quality tire anyway.
Michelin uses polyurethane bands instead of metal, so there's probably even less chance of a catastrophic failure.
