New summer tires humming / droning on c63
I've installed a new set of Hankook Ventus V12 EVO2 K120 summer tires on my 2011 c63 AMG stock 18 inch rims (235/40 r18 on the front and a tad wider 265/35 r18 on the rear).
The grip is awesome but I'm getting a loud humming / droning sound from 80 to 100 km/h (50 mph - 62 mph).
My wheel bearings and suspension was checked and alignment was done 2 times - everything is perfect. Moreover while I was on my winter tires - everything was ok.
The k120 tire is advertised as being very quiet. The temperature where I live is still rather chilly, but still above zero.
I get this noise on perfectly even roads but it changes tone dependant on the grain of the road surface.
The car has only 32000 miles on the odometer so I really doubt it's the bearings.
Has anyone had this problem on the c63?
I scanned through c63 owner reviews on the TireRack website - they all seem to be unhappy with the noise levels of this brand of tire.
I should have gotten the good old Hankook RS3 which I admired on my 400 hp mk6 Golf GTI
Surprisingly the bearing demonstrates no play when checked the classic way.
You have dealt with all the mechanical causes and these are new tires. The issue was not present before change but is now. So to Carlo's point. It's the tires.
The point about 7C is exactly right but even so the rubber will be stiff above that until you get up to higher temps.
Thanks for the heads up. I expect I will need tires soon so I know what not to buy.
Dude!
The faulty wheel hub had zero play! The Mercedes dealer sweared that all suspension components were perfect.
The humming sound decreased when I turned right, so I decided to give a shot and change the right hub. Well it fixed everything up!
When I got my car last September I could not get it on the highway due to rain and very heavy traffic so I never got it to speed.
The next day when I did I heard this droning noise from the front end which when I turned the wheel slightly right went away and got worse when I turned the wheel slightly left. Close examination of the front tires showed perfectly even wear across the surface so I took tires out of the equation and figured bearings.
I took it in, they confirmed it was and they changed both. Problem solved.Sound familiar?
Now do yourself a favour IF your car is under warranty.
Go back and argue they should have changed both. You now have mis-matched bearings and the other will go too.
Glad you got it sorted. It is a damned annoying noise isn't it.
Now I am trying to resolve my final nuisance - a whining/groaning engine speed dependant sound from my motor, which increases when I drive through more or less deep puddles with my left front wheel.
I described the problem here, but unfortunately didn't receive any feedback yet:
https://mbworld.org/forums/c63-amg-w...ving-rain.html
