Oil pressure on track
Received 2,810 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Is anyone monitoring this? I'm starting to get a little bit worried about oil starvation, given the forces at play and that we don't have the dry sump of the M159. AMG had to do that for a reason other than getting the CG down, right? Or maybe that's just it.
Has anyone hooked up a real oil pressure gauge, or is there a way I can tap into the existing sensor (surely there is one?) and track it with an app or other datalogger?
GeorgeSmooth talked about how well our engines are oiled in a post here once (https://mbworld.org/forums/c63-amg-w...ml#post5297077), and said basically that you would have to turn the engine upside down to starve it of oil. I'm still wondering if something like an accusump might be a good idea just as a preventative measure? Maybe I'm thinking too much about this, but I'll need data to determine that.
An accusump seems like the logical solution. It's cheap and effective. It's not a dry sump, but massively less expensive and complex. Canton Racing Products seem to make the most popular ones, and at $275 sounds like cheap insurance to me.
https://www.cantonracingproducts.com...ion&key=24-006
Here's some of the tech behind it. It's pretty simple - when it detects oil pressure dropping, it sends more oil to the engine from the 3qt accumulator, then refills when the pressure goes back up. I'm starting to like this idea.
http://www.accusump.com/accusump_tech.html#whatis
First step is to monitor oil pressure. If anyone has thoughts on this would be appreciated.
Forget it. The more I read about the M156 oiling system, the more I'm realizing that it's total overkill. Still might like to monitor pressure though...
For future reference, here's a good post on the topic of M156 oiling. https://mbworld.org/forums/c63-amg-w...ml#post4087557
And some more detail from MBCA (this is a great series of technical articles on the M156 if you haven't seen them). The M156 is ridiculously overengineered.
https://www.mbca.org/star-article/ma...-amg-63-engine
https://www.mbca.org/star-article/ma...ne-refinements
julours (05-02-2017)
BLKROKT (05-02-2017)
If you liked that, check out the videos on this page about how the M156 is built. Love this stuff. Yeah I'm a nerd.
http://australiancar.reviews/mercedesbenz_M156_M159.php
there are some hints of what Mercedes themselves think about oiling of the C63.
Even although there is an oil temperature sensor and coolant temperature can be pulled and read in numbers and contents of tank can be pulled in gallons and temperature of transmission can be read, there is no rig whatsoever that is dorment, that can be accessed, to read the oil pressure.
This while all older Mercedes had a dashboard display of oil pressure.
So they don't seem worried.
The factory recommended method of shop checking the pressure involves replacing the oil filter plastic cap with one that has a pre-drilled and tapped opening for a sensor, and then read this pressure.
I thought about getting one, thinking that maybe it's not plastic, like the current one, but I can't decide where I would put the gauge.
Also, clearly the pressure reading differs, depending where you read it and Mercedes feels that the accurate readings are there, at the filter.
As far as at the track, oil temperature affects oil pressure greatly.
Mercedes took great care of cooling the oil.
As far as accusump, to me the best use of it, is not for the track, but for pre-lubrication.
A great percentage of the engine wear (I think I remember 3-5%) occurs in the one or two seconds at start up before the oil pressure is established, during cranking.
SO if you pre-lubricate, you increase the life of your engine 3-5%.
So if you hook up the accusump to discharge 5 PSI of oil, THEN crank, while the oil pressure ALREADY is 5 PSI, that would be good...
http://www.germänboost.com/showthrea...198#post304198
Originally Posted by George
Since we had some prep to do with the cam removal we spun the motor around and removed the oil sump. We where really shocked when we saw the size of the oil pump. The oil system is overkill in this car and the oil pump alone weighed close to 5kg. My engine builder mentioned that after seeing this the dry sump system on the SLS was either fitted to lower the motor or for just having something nice on the sales prospectus.
BLKROKT (05-03-2017)
Here's is thread over on germänboost. Make sure you fix the ä below...
There's also an auxiliary pump that moves oil from the front of the pan back to the sump at the rear (pan is split-level due to the crossmember). Cool engineering.
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
Just saw this thread and was going to link to the one at https://mbworld.org/forums/c63-amg-w...ystem-c63.html but I gather you've already seen it. In short, oil starvation is not an issue. The oil foaming from being mechanically beaten and aerated is of greater concern, which is why the MB shop foreman / part-time race engine builder that works on my Merc told me to only fill up halfway between the low and high marks on the dipstick before track events (and top up between sessions if needed, but again do not go above the halfway point), and change the oil often as the foaming and high oil temperatures will significantly accelerate oil oxidation. Most decent synthetics contain a good amount of anti-foaming additives so if the oil is fresh and you keep the level at the halfway mark, oil starvation on the M156 should not be an issue.
I have an Accusump on the track rat (those engines chronically suffer from #2 rod bearing failures, and I am not sure if it actually helps with that particular issue). If you decide to install one (on any car), do *NOT* mount it in the cabin. I've heard of several of them letting go in a rather spectacular fashion, and sitting next to a reservoir of hot oil pressurized to 5 bar does make me somewhat uncomfortable...
Interesting read. Threads like these are the valuable ones.
As a side note, I run an Accusump in my Lotus. I agree that one of the reasons I like it is the pre-lubrication - especially given the fact that I have a big turbo to lubricate too.
