Keeping her running cooler
Radiator blockoff plate
Use SDS to enable "desert mode" (radiator fan runs longer and starts at lower temp)
180deg thermostat
Phenolic intake spacers
Hood vents and/or spacers
Enlarged bumper openings
Redline Waterwetter
Do a search and you'll find threads on most of this stuff
Dave
Edit - FLEX Run it on FLEX, Switch back and forth as you wish from 93 to E85, Drop your temps AND pick up like 25-30whp in the process - booyah!
Would love to run E85 but its not local in my area.
- This never heard of it, looked it up and it looks perfect for what i'm trying to achieve. Did anyone make a kit or its just fab your own? Seems its not be kitted https://mbworld.org/forums/c63-amg-w...r-cool-11.html
- This never heard of and will search.
180deg thermostat
- Wondering what needs to be done tune wise differently for this mod.
- Ran them on other cars before wasn't sure how much it makes a difference on the c63's
- Always wondering if the BS hood vents actually make a difference or it was just most for looks.
- Assuming this has been done before?
Did you perhaps get a batch of bad fuel, causing knock, and pulling timing?
How many miles? what is the cond of the vehicle? you might consider a dyno session to make sure all is good.
I really don't notice a drop in power in summer vs winter..... I just notice an increase in traction in summer VS extreme winter... which I attributed to cold tires/road surface.
Are you noticing this when sitting in bumper to bumper traffic with AC ON.... just heat-soaking? then you hammer it?
Or do you notice this even while cruising at speed.... not acute heat-soak?
GL.
Do like the idea of 180 thermostat (need to learn more regarding the tune). Love the blocker plate mod big time, would love for there to be a kit available since i don't have the abilities to cut something like that.
i would save your money on that mod imo
If you drive a 12-15(W204) Need4Speed has a New never installed mercedes 440 cooling kit for sale Cheap!
Might be backordered if you get thru MB stealer.
This is a great Mod.
180deg thermostat
Redline Waterwetter
When I search the two part numbers, one comes up as optional cooling system, which makes sense. The other, however, comes up as a W204 grill panel...which doesn't make sense.
