Resonator delete vs secondary cat delete
Yes you do lose a little power from straights, hardly noticeable though. I remember reading on the forums the xpipe has a different sound and straights were more favorable. Ive heard straights in person and ended up going with those. Hope it helps.
Do you feel any power loss? supposedly the X and H pipe help to even out the banks.
Or are you saying x-pipe over straight nets more power in place of the sec cats?
#33
i'm speaking of straights in place of resonator, hoping that guy is also speaking about resonator. Straights in sec cats would boost a little bit of power if I'm not mistaken.
#34
Received 2,842 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
I'm sorry, but you guys are dreaming if you think you're noticing any difference of 2 or 3 or even 5hp difference switching between h-pipe, x-pipe and straight pipes. Never mind that those variances probably are not even an absolute terms, but rather at points on or shifts of the curve.
Seriously, that's ~1% of the total output. You guys are imagining things. Just do whatever sounds best, because the power and torque differences are negligible. Anything you're "noticing" is more likely a result of really good drugs. Or atmospheric differences. Pick one. It ain't the type of pipe on your car.
#35
BUT. I would swear that I have a little flat spot in my torque curve since I did 2nd cat delete and replaced with straight pipe. Just a little.....flat spot...and gone. But I have no numbers to support that, it's just a feeling, and that feeling could be caused/affected by the sound, and yet......
Well, I suppose THAT'S what a dyno would prove, isn't it?
Off to Temecula!!!
#36
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Honestly I think straight piping the resonator makes it sound worse. X-pipe keeps it more refined. Straight piping the cats is definitely the way to go, and joined with x-pipe should work well.
#37
2014 C63 Coupe
#38
Well there are 100s of posts on this in great detail with videos and all but I won't be that be that guy that says it. And since I know because I took the time to read them all. Wait... Never mind. But secondary is where you want to go if you want to keep the AMG sound. Which I got done right with 409 SS. Sound is amazing. How it should of been stock. Resonator delete you will get more Rasp (race car) sound. I like both sound differences even with both deleted. But just not for me. I like the AMG growl with just Secondary. Idk if this video link will work but I took a couple videos of mine and posted them on Facebook. If it works great if not oh well. I tried.... But secondary is where its at IMO. No HP gain that I can feel. Minus the sound makes u feel it's faster then it was.
Facebook Post
#39
