C63 AMG (W204) 2008 - 2015
My Merc is Mad "C63 AMG Tracktool"
Old Aug 24, 2017 | 02:34 PM
Tex5's Avatar
CLK 63 AMG Black Series, A45 AMG
Hi
I would be interesting on information about the rear wing. Is it removable?
Old Sep 7, 2017 | 03:50 PM
joe_quax's Avatar
C63 AMG W204 2007
Yes, its mounted to the bottom of the trunk. You can Remove it anytime with only 10 Bolts.
Old Sep 8, 2017 | 09:58 PM
JQuala's Avatar
2015 W204 c63 507
Curious about hand brake
whats that about? How'd you make it fit and is it controlling the brakes or the e brakes. I've always wanted one in a c63
Old Sep 11, 2017 | 08:53 AM
joe_quax's Avatar
C63 AMG W204 2007
It's fitted to the transmission tunnel and it's controlling the brake with a sensor. Next week I get my car back and then I can take some pictures to show you how its done.
I am running 10w60 castrol TSW Oil at the moment. Use it over 7.000 miles now. Every trackday I fill in new Oil and get rid of the old used Oil. It's not expensive and I feel better. You dont have to change the filter. It'S good for at least 3-4 Oil changes if you switch Oil every 600km. But you have to know that I am driving my car mostly (95%) on track and you can believe me I drive the sh*t out of it .
So far no problems with the car.
Old Sep 11, 2017 | 09:04 AM
joe_quax's Avatar
C63 AMG W204 2007
Originally Posted by Vladds
OP, in Germany, the C63 had a no sunroof option too, no? so you are able to replace all panels with the no sunroof panels?
Also, how long have you run the 15W50 and do you have a cold start-up video?
Hi Vladds,
I have no idea but I dont think that there was a no sunroof option available in Europe. Like I said I think they used a carbon fibre plate to close the hole of the missing sunroof. I've never looked at it closely because my rollover cage is in the way.. I will take you a picture as soon as I get the car back at Mugello Circuit next week to show how it looks like. I was running the Oil for a few thousand miles but now I switched to Castrol 10W60
Cheers
Old Sep 11, 2017 | 09:09 AM
Vladds's Avatar
2010 C63 2019 GLA45
Post the cold start video, then this will be helpful.
Old Sep 11, 2017 | 09:13 AM
  #32
Vladds's Avatar
2010 C63 2019 GLA45
There was a no sunroof option for the Black series coupe for the Japan market too, a forum member has the car.
Also it doesn't look like the roof is carbon, maybe I have it wrong though.
The importance is that there are parts that weight savings guys can buy, both for the roof panel as well as the ceiling lining and the blank out for the sunroof switch in the overhead panel.
Deleting options is big in car communities for weight savings, but the most desirable is retrofitting a factory delete.
The factory deletes can be expensive too.
But one can buy them used.
Old Sep 11, 2017 | 09:21 AM
  #33
joe_quax's Avatar
C63 AMG W204 2007
I try to do everything as affordable as possible. The car is not worth spending thousands of Euros in Carbonfibre parts. You just have to remove the things you are driving aroung which makes no sense. I removed the GPS, Commandsystem, Airconditioning, sunroof, interior parts, parts of the wiring, seats. I have installed macrolone windows now on driver and passenger side and refreshed my suspension with a new damper/spring setup for the rear axle.
During the wintertime I will install headers and adjust the software. I will install the HMS widebody rear fenders too to get more grip on the rear axle with wider tyres. More mechanical grip is a must have for me now
Old Sep 14, 2017 | 07:23 AM
  #34
Vladds's Avatar
2010 C63 2019 GLA45
So for Europe, the front fenders don't have the rectangular position lights, I didn't realize this.
Old Sep 23, 2017 | 11:59 AM
  #35
Ludedude's Avatar
2014 C63 Coupe
Gonna be tough to get a cheeseburger, fries and a shake through that....
Old Sep 24, 2017 | 12:01 PM
  #36
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
I can't tell from the pictures, but have you cut a rectangular hole in the center of your front bumper cover in order to get more air flow to the transmission cooler? I like it. Did you also cut the bumper support behind the cover? (MBNRG - another possible solution)
Your car makes me all tingly. Thanks.
Old Sep 25, 2017 | 10:39 AM
  #37
BLKROKT's Avatar
Originally Posted by joe_quax
Hi! Yes on my "race version" front bumper I've cutted a horizontal hole to get more air flow to the transmission cooler, thats absolutely correct. Yes, I also removed the bumper support, climate housing etc to increase the airflow. My big frontsplitter replaces most of the stock underbody covers most at the front and channels the air underneath the car. To make sure that I dont lose the frontwing while driving with high speeds we fixed it with brackets on the frame and constructed customized brackets directly behind the bumper. It has holes with little fins to suck out the hot air of the engine bay aswell what is really important for heat management on the track. I take pictures next time when I am in my garage
Cheers Joe
Awesome Joe, thanks for confirming. Was the hole there effective in lowering transmission temps? Did you happen to take before/after readings? I'd be happy to cut another hole in my bumper if it works. I also have the 44O cooling kit, so was considering moving the trans cooler down to the bottom of the radiator where the oil cooler used to be (is now lying flat). But if your hole works, that's even easier. Thanks
Old Sep 25, 2017 | 11:17 AM
  #38
joe_quax's Avatar
C63 AMG W204 2007
Hey! No problem. Unfortunately the benefit was not as much as I thought it would be but at least it helped a littlebit If you can get around cutting your bumper I would suggest to avoid it Do your track your car aswell?
Old Nov 21, 2017 | 08:30 AM
  #39
BLKROKT's Avatar
Car looks great Joe What size are those quad exhaust tips, 82mm? I’m reworking my exhaust and was thinking of quad 4” DTM tips, but I like how yours look.
I’d swap in new O2 sensors first and see if that does it. Did you pull the codes yet?
Old Nov 26, 2017 | 09:25 PM
  #40
julours's Avatar
C63 AMG w204
Hi C63 AMG fans!
Brakes: Front SLS GT3 Brake Brembo Racing 380/36 Disc PFC01 Pads / Rear Original with Pagid RSL1 Pads / Castrol SRF Fluid and flexlining / brakecooling through ducts and panels
Cheers
joe
Hi Joe,
I have been reading your thread and looking at it as a very reference for C63 tracking. Thanks for sharing your experience.
I always have trouble with my brakes, using both the original 1 piece or 2 piece 360mm OEM. I was looking at the racingbrake upgrade to 390mm but this also means going from 18" to 19" wheels, i want to keep 18".
Can you please share more about your brake setting? :
Front SLS GT3 Brake Brembo Racing 380/36 Disc --> where did you source that? did you keep the original caliper? how much does it cost to buy the set and how much to replace the disks? do you mind sharing some photos?
brakecooling through ducts and panels --> do you mind sharing some photos?
Thanks!
Julien
Old Nov 27, 2017 | 01:56 AM
  #41
cracklin's Avatar
W126 500 SEC, W208 CLK55 AMG (TRACK CAR), W163 ML350, W164 ML500, 2009 W204 C63 (TRACK CAR, 190E 2.6
Smile
Hey Joe,
What a fantastic post! Perfect timing for me as I am also just starting to prep a car purely for track work.
Mine is a 2008 W204 and so far I've only upgraded the Diff to a Drexler LSD, fitted KW Coilovers, added the Eurocharged V7 Tune, installed Supersprint Headers and Catless Downpipes and a Weistec Transmission Pan.
The next lot of modifications is to install a secondary Transmission Oil Cooler and Pump in the rear defuser and later a Diff Cooler.
I will be removing the primary Transmission Cooler Fan (as it restricts airflow at high speed), remove the two driving/fog lights and use the location for the Brake Duct Intakes.
At the moment I'm running 18 x 9.5" ET 52 rims fitted with 265/35/18 Hankook Z221 Semi Slicks both front/ rear and also have another set fitted with Yokohama AO 50's and stock brakes with EBC Yellow Stuff Pads.
I have a set of 390mm and 340mm (rear) two-piece rotors which I'd like to fit but unfortunately would have to change to 19" wheels and also find a set of brake caliper offset brackets.
I currently run a W208 CLK55 on the track and learned a long time ago that if you haven't got the handling set up wright, horse power will get you absolutely nowhere and thats why I'm going to take this build very slowly.
I'm only competing in general Club Racing and Supersprints etc and therefore I won't be stripping the weight from the car for at least the next month or two and all going well I should have the Rollcage installed before the first major race meeting in late January.
Here in Australia we have just finished our Club Racing competition for the year and as the weather is heating up it will be a good time get in some "Test & Tune" days at the track and hopefully iron out the heating problems our cars suffer.
I look forward to discussing our progress in the near future and I'm sure you already realise as I have, you only have to ask and you will definitely get assistance from the Forum.
Cheers--------JR.
Old Jan 29, 2018 | 04:03 PM
  #42
joe_quax's Avatar
C63 AMG W204 2007
Originally Posted by cracklin
Hey Joe,
Cheers--------JR.
Wow that sounds great! Excited to see some pictures about your build !
BR Joe
Old Jan 30, 2018 | 01:58 PM
  #43
RacingBrake's Avatar
Former Vendor of MBWorld
CLS550
Weight savings:
biggest weight savings:
1) remove full interior and electricity which is not needed
2) install bucket seets instead of the full adjustable OEM leather seats
3) remove sunroof
4) install carbonfibre doors
5) titanium exhaust system
6) lightweight battery
7) go for 18" rims --> much better acceleration
uniball bushes and solid alu subframe bushings which have been customized for my car. I couldnt find any after market product so I had to let them built by a local shop that could drill aluminum.
Cheers joe
Carbon Ceramic brake can significantly reduce "un-sprung" weight by about 20-30 lbs per axle.
Old Apr 17, 2018 | 04:59 AM
  #44
joe_quax's Avatar
C63 AMG W204 2007
ello guys,
now finally the season has started again.
Here the first onboard of this year. Driving very soft just to check out how the car works. Big wing was mounted but really not necessary at that track. Missing aroung 15mph on the straights to achieve a nice laptime but in the end the car worked out great and I am very happy with it!
Cheers
Old Apr 17, 2018 | 07:54 AM
  #45
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Full throttle to red in each gear passing a bmw on the inside after corner exit is driving it very soft huh?
I hope your fake taxi's rear tow hook doesn't catch on fire from the tail pipe.
Old Apr 17, 2018 | 08:00 AM
  #46
joe_quax's Avatar
C63 AMG W204 2007
I could have been later on the brake and earlier on the throttle
I still have cats so I dont think it will catch fire :P
Old Apr 17, 2018 | 09:29 AM
  #47
BLKROKT's Avatar
Duplicate post delete pls
Old Apr 17, 2018 | 09:30 AM
  #48
BLKROKT's Avatar
Old Apr 17, 2018 | 09:32 AM
  #49
BLKROKT's Avatar
That looks like a fun little track, thanks for posting. I had never heard of that one before.
Tell us us more about your roll cage? Like that wing sticker too.
Nice “easy” lap haha. Anyway what’s with the no fire suit or extinguisher?
And thanks for the tip on the front bumper opening for trans cooling. I’ve got Watkins Glen next week and think it will help there.
Old Apr 17, 2018 | 01:38 PM
  #50
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
Looking really nice, man.
