C63 AMG (W204) 2008 - 2015
ESP ABS Inoperative after brake pad change
Old Aug 11, 2017 | 05:53 PM
shaneatlas's Avatar
2012 c63 AMG Edition 1
Exclamation ESP ABS Inoperative after brake pad change
Hi everyone,
I just changed my brake pads and when I started driving, the following error popped up on my dash: "ESP ABS inoperative. See owners manual."
I took it out for a short ride and did a few hard stops. The brakes appear to be working fine. I scanned and cleared the error codes, but the following one persists:
"The signal of component 'L6/2 (Right front axle rpm sensor)' is implausable."
I replaced the brake pad wear sensor and I believe everything was plugged in properly, but before I take off the tire and check on it again, I wanted to see if you guys have any suggestions.
Thanks!
Old Aug 11, 2017 | 08:49 PM
Euler's Avatar
2008 C63, 2008 ML550, 2014 KTM 500 XC W, John Deere 990
Looks like you may have somehow damaged the ABS sensor on one of those wheels. Or at least knocked a wire loose.
Old Aug 12, 2017 | 12:18 AM
shaneatlas's Avatar
Where is the ABS sensor? The only wire that I (thought I) touched was the pad wear sensor.
Old Aug 12, 2017 | 01:11 AM
bhamg's Avatar
C63 AMG
It might be similar to the W203:
http://www.pelicanparts.com/techarti...eplacement.htm
Old Aug 12, 2017 | 04:10 AM
Alex.currie44's Avatar
2009 SLK55 AMG. & 2022 GLA250 4Matic
Old Aug 12, 2017 | 12:25 PM
shaneatlas's Avatar
Originally Posted by Alex.currie44
Ah, I recognize this. Thanks for the help, guys. Hopefully it is just loose.
Old Aug 12, 2017 | 12:26 PM
Savage-wp's Avatar
2014 Mercedes C63 AMG 507 Edition
You've either damaged the ABS sensor, or you have managed to pull the plug out.
