C63 AMG (W204) 2008 - 2015
Tire wear
Old 08-15-2017, 05:24 PM
ecohen2's Avatar
Here are the before and after numbers... It does not look nearly as bad as you would think based on the wear. I guess ill know more end of next week..
Ed
Old 08-15-2017, 08:34 PM
QWKSNKE's Avatar
09 Carrera S, , 03 F250 CC FX4
Originally Posted by D3-AMG
I seem to recall the FAQ section talking about this some. I remember seeing Toe numbers for the C63 as being .25-.50 (this is the range allowed to be "in spec" for the alignment) vs. E63/other63 being closer to 0. Other 63s have more rear weight. But as pointed out above, you can get the toe changed to essentially 0, just need to be careful about 0.
No noticeable difference on driving including the occasional late night 160 mph sprints
D3-AMG (08-17-2017)
Old 08-15-2017, 08:43 PM
Dogtag114's Avatar
2009 c63
Originally Posted by 1Lop2K5C
I have been running 265 19in profile with .24-.25 toe setting and getting good wear on the tires.
I too dropped my toe from 30 to 24 last year and have even wear.
Old 08-15-2017, 08:54 PM
Vladds's Avatar
2010 C63 2019 GLA45
This is PFL, so there's an angle in decimal degrees that you then add hexagesimal degrees. My recollection was wrong.
Even so, the total toe looks to be over 6 degrees, not like above. Unless that angle means something else.
KrisKeeney's Avatar
2016 E63S W212 Matte Gray
Holy s**t: on what type of road are you able to drive 160 mph?
Old 08-15-2017, 09:38 PM
Dogtag114's Avatar
2009 c63
Too many deer where I live to drive that fast... this happens
https://youtu.be/euTIioGgmPE
Old 08-15-2017, 10:03 PM
  #32
QWKSNKE's Avatar
nice straight area of interstate
Quick Reply: Tire wear
