C63 AMG (W204) 2008 - 2015
C63 sway bars
Old Oct 14, 2017 | 02:53 PM
joc's Avatar
joc
2015 E350 4 matis, 2003- 911 porsche
C63 sway bars
Will C63 sway bars fit and improve corning on 2014 C350 sport
Old Oct 14, 2017 | 05:56 PM
Cozy's Avatar
C63
If they fit, then I'd imagine yes if my assumption is that they're thicker overall.
On my old 135i I swapped in the thicker M3 sway bars and it cornered much flatter however, I felt that the thicker rear was too much and induced oversteer. It was a problem until I swapped in M3 control arms, subframe bushings, upgraded shocks and threw in a mechanical differential. Something to perhaps consider although the front bar only might help your turn-in.
Old Oct 14, 2017 | 05:58 PM
joc's Avatar
joc
Thanks, Some reports say just do the front one and then try it,is that correct.
Old Oct 14, 2017 | 06:01 PM
Cozy's Avatar
C63
Probably a good place to start. Some guys on here track their AMGs though so they'd be best placed to say, having modified their suspension and knowing it well.
Old Oct 14, 2017 | 10:22 PM
joc's Avatar
joc
Old Oct 15, 2017 | 12:02 PM
joc's Avatar
joc
Just looking for better street use, used to have a C55 and have driven the C63 which stayed flatter in the corners, so trying to get the C350 close to that level, while still maintaining a good ride on the hwy. The C63 bars are 1 mm less than the Eibech, so its a matter of what will be most cost effective. There are some threads that say just do the front and see how it feels?
Old Oct 15, 2017 | 01:06 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Plenty of threads in the C-Class section about exactly this. It’s a significant increase in bar size and makes a difference. That’s what prompted me to buy the Eibach swaybars for the regular W204, knowing that they would fit the C63 too.
Old Oct 15, 2017 | 01:10 PM
Ambystom01's Avatar
2013 C63 AMG
Did the Eibach bars make a difference over the stock C63 bars? I know you'd said before that the chassis stiffening bars were a large improvement.
