C63 AMG (W204) 2008 - 2015
NEED ADVICE HEADERS VS STAGE 1 VS NEW W205
Old Oct 23, 2017 | 06:10 AM
  #51
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Originally Posted by black63s
It €™s a know fact these cars fall on their face with stock turbos but you €™d have no clue and your friends car is slow as **** because I trapped 119 stock but good luck with your 204 life.
Hey guess what. Nobody gives a *** about you or your ugly slow car. Why don’t you stop baiting members to fight and go ********** in the W205 forum with your C450 friends and leave the AMG enthusiasts alone.
Old Oct 23, 2017 | 07:18 AM
  #52
mr747's Avatar
c63
lol conversion over LOL
Old Oct 23, 2017 | 08:59 AM
  #53
skratch77's Avatar
2005 E55
It’s a know fact these cars fall on their face with stock turbos but you’d have no clue and your friends car is slow as **** because I trapped 119 stock but good luck with your 204 life.
Lol ok bud*
Just look at the dyno I posted of a c63s.it makes it's power all the way to 7k and is missing 120rwt that your car had.
Your probably miss firing with your wire hack piggyback and the STOCK ecu is saving your car cutting timing and dumping fuel after 5k.
I'm done but here is a healthy c63s that does not look like an 80s muscle car that only revs to 4000 rpms then dies up top.
No one here is disputing a modded 205 is fast as ****.we are calling out a stock car is making 571rwt and 600rwt with full exhaust.
The dyno I showed you has 4 pulls all bearing 480rwt and that is exactly what a healthy c63s is making*
Old Oct 23, 2017 | 09:56 AM
  #54
NotABaller's Avatar
2012 C63, 2014 E550
Quick question, if I got a car with a graph like OP's, then should I just upshift at around 5.5k (slightly past max HP)? Upshifting at 5000-5500 and losing 2000 revs would put me at the same power level as wringing it out to redline.
Old Oct 23, 2017 | 11:22 AM
  #55
bentz69's Avatar
'16 CLS63S
Yea that dyno sheet is indicating you have a problem with your car. Instead of trying to gloat about your numbers, use your dyno sheet as a tool to diagnose the problem with your car after 5000rpms. Are monitoring knock? How does the timing look throughout the powerband and specifically after 5000? How is the air/fuel? If you dont know these answers then you should go back to the drawing board and check
If you put downpipes on your car and what appears to the rest of us as a piggyback/tune, then perhaps your turbos are running out of steam in the upper rpms which is why they fall off. Either way, needs to be fixed and your car will be much happier. Those turbos should peak around 5000 (which they do in your graph) BUT they should hold steady till redline.
Old Nov 5, 2017 | 12:47 AM
  #56
AMGC's Avatar
Mosselman 190E 16V+ C63S+ Abarth 595
back to the OP...with only have 10k to put down I am calling this a fantasy anyways lol
Old Nov 9, 2017 | 10:34 PM
  #57
ecmexchange's Avatar
Former Vendor of MBWorld
na
You ever figure out the problem?
Old Nov 10, 2017 | 04:01 PM
  #58
silverstar11909's Avatar
c class
Pretty much decided to go in the route of a used w205, anyone looking for a 13 satin grey wrapped c63 in Los Angeles let me know!!!
Old Nov 11, 2017 | 05:25 PM
  #59
Mag1c Carp3t's Avatar
2009 C63 AMG
This was an interesting read.
Old Nov 14, 2017 | 12:33 AM
  #60
na
I gotta say, I completely agree. Though, the drama it turned into isn't as much fun.
