Intake switcharoo....project
yes this intake will not net you 10hp more than ROW or Carbonio...it will give whopping +1-3 whp more on its own lol....unknown what power level is now....will dyno it one last time with the tune and see where we are at. I shared torque app hp levels with you in last post but not sure if that is even remotely correct.
thanks for the imputs
Finally did the last log and did my best to get it all fair and tidy (still may not be). Torque app is not what you would call super accurate in terms of taking data inputs exactly the same time. Ive been told some of the points are just not as a good as a pro logging tool that tuners use but it could give a general idea.
I removed the Orion intake and placed back the carbonio airboxes + RAM air kit. The new tune stayed in the car along with the carbonio. MAF readings showed increased flow on low to mid range, dropping below carbonio set up at around 70-90 mph (maybe the ram air?). At 5500 to 7k....the Carbonio set starting making more power and torque. Not sure again if this is the RAM air or not as I will need to do a 4th test to do that so will try that later. Folks are free to share log files with me too just to compare.
The run was a full 3rd gear starting 2k rpm WOT to redline. Nothing else was done. I will dyno the car again in a week or so to see what changes compared to whopping +1-3HP gain I will get under the new tune.
Thanks for watching!!
