C63 AMG (W204) 2008 - 2015
WILL IT FIT (
Old Nov 6, 2017 | 03:14 PM
Amr_c63's Avatar
14 polar white E550
WILL IT FIT (
Hey guys quick and easy question you guys might know will et45 wheels work for the rear of my coupe and also et35 for the front . My current setup is stock 18s with 10mm spacers all around that make the wheels look flush to the fenders which im fine with . Looking for at this setup for my winter wheels .
thanks alex
Old Nov 6, 2017 | 03:19 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
You might want to change your thread title if you want help. Just sayin. ¯\_(ツ)_/¯
Old Nov 6, 2017 | 03:27 PM
Infiniti's Avatar
a unicorn tuned p30 e63
LOL my dude said "no homo" in the title of his thread on an amg forum. WTF is going on around here. btw bro, most guys that say no homo usually feel guilty or aren't secure about theirs. good luck with the wheels tho if you have any issues getting them on use a little lube.
Old Nov 6, 2017 | 03:38 PM
Amr_c63's Avatar
14 polar white E550
click bait bro that's all . So my question still stands for an answer . Help please ??
Old Nov 6, 2017 | 05:10 PM
MTV10's Avatar
E55 AMG & C63 AMG
These guys above.... ^^^ fkn useless comments.
Yes they will fit.
OEM wheels are +54 rear and +45 front.
Old Nov 6, 2017 | 09:30 PM
Amr_c63's Avatar
14 polar white E550
Yes they will fit.
so what I'm looking to get fronts 19x8.5 et35 , rears 19x9.5 et40 will be good to go? These will be my snows with 245/40 blizzaks lm32
Old Nov 6, 2017 | 11:59 PM
Alex.currie44's Avatar
2009 SLK55 AMG. & 2022 GLA250 4Matic
The wheels should fit but why are you going 1" wider and using the same tire on all 4 corners? Strikes me as odd. If you are going same tire on all 4 why not go square on the wheels as well then you can mover them front to back season to season.
There are lots of fitment comparison tools on line.
Old Nov 7, 2017 | 07:18 AM
Amr_c63's Avatar
14 polar white E550
I have a square set of blizzaks with like 2k miles on them and found a set of rims in those sizes for very cheap .
Old Nov 7, 2017 | 09:32 AM
How cheap is cheap? I am not qualified to say for sure but you are stretching a tire tha this optimal on an 8 to an 8.5 in the front but to a 9.5 in the rear. I would be concerned about it popping off under the higher side loads when cornering. Do yourself a favour. Go ask an expert about doing that just to be sure you don't wreck your car for the sake of saving a few bucks or worse injure someon.
For sure the rim is going to stick way out relative to the tread and the side walls will slope in from the rim to the tread. Saw a Honda Civic with exactly the same problem a couple of weeks ago. The rims sure showed well but curb rash was evident and the tire was really narrow to the rim width. Just sayin"
Old Nov 7, 2017 | 09:40 AM
MTV10's Avatar
E55 AMG & C63 AMG
Will be good as long as you're not lowered. Rear might be close...
I'm running a 235/35R19 with a final et of 30 up front. 255/35R19 with a final et of 42 in the rear.
Rims are OEM 19's :
F: 19x8
R: 19x9
Old Nov 7, 2017 | 10:06 AM
Hey mate! Just noticed I misread you size. 245s should be OK.
Old Nov 7, 2017 | 10:12 AM
Amr_c63's Avatar
14 polar white E550
ok awesome thanks everyone !
