C63 AMG (W204) 2008 - 2015
Side marker bulb error... with new bulb
Old Nov 7, 2017 | 08:52 AM
Dogtag114's Avatar
2009 c63
So... I validated the bulb was good by switching them but my front right will not light up and it throwing the error... any ideas?
Worse yet, they are smoked so bulbs only there to avoid errors... ugh
Old Nov 16, 2017 | 02:55 PM
Dogtag114's Avatar
2009 c63
Bump... crickets... anyone?
Old Nov 16, 2017 | 04:54 PM
bentz69's Avatar
'16 CLS63S
So your saying its a regular filament bulb, u swapped the bulb with a known working bulb and your still getting the error on the same side?
Try the basics. Check the socket to ensure the wires are connected and didn't break loose from the inside. With the lights on, stick a multi meter in there to see if your getting power. Wouldn't be a fuse since more bulbs would be off. Maybe a glitch in the ecu so try disconnecting the battery?
Try that if you haven't done so yet and report back
Old Nov 16, 2017 | 05:57 PM
LSAMG's Avatar
2013 C63 AMG Sedan
This happened to me last week. It was a bad/rusted socket. Replacement was 15.00
hth
LS
Old Nov 16, 2017 | 06:29 PM
Dogtag114's Avatar
2009 c63
Thanks both... was suspecting the socket.
as for testing with a multimeter... i assume I ah ave to cut the wires to prove it’s a bad socket?
Old Nov 16, 2017 | 07:11 PM
AMG3.2's Avatar
C63 AMG, P30
Not necessarily. I like to test with this tool. One end clips on to the factory ground, the other side touches a live source and the piece lights up.
https://www.amazon.com/gp/product/B01EMAOBHG/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B01EMAOBHG/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
Old Nov 16, 2017 | 10:31 PM
Alex.currie44's Avatar
2009 SLK55 AMG. & 2022 GLA250 4Matic
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Your suggestion is similar to Bentz above except that a meter voltage reading is clearer indication of power. All a circuit tester like this will just tell you there is some voltage but not how much.
I too suspect a bad socket.
Old Nov 25, 2017 | 07:47 PM
Dogtag114's Avatar
2009 c63
Ended up being a frayed wire in a crevice... easy fix.
Old Nov 26, 2017 | 11:23 AM
Mort's Avatar
Good for you. Problems like that can be hard to diagnose.
