Tech question- Brakes
Received 2,810 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Congrats for being right on that. You were wrong about practically everything else you posted.
Oh no you didnt follow the instructions whatever will you do
I almost hate to post this after the above debate but it is a fact. Last year I had removed my entire ABS module, the master cylinder, and all brake lines for the front of my C63. Essentially all the fluid was drained from everything. When I reinstalled all the lines and pieces I gravity bled the entire system starting with the usual right rear and everything works perfectly. I have had absolutely no issues with brake pedal feel or CELs. Maybe I was just lucky, but for the past 40 years and many many cars I have never had a problem with gravity bleeding.
I had a soft pedal when I first did a pressure bleed on this car years back. Slowly pumping the brake pedal while bleeding made a huge difference.
LOL, you do a couple track days and minor maintenance on your car and you think you're an AMG certified master mechanic now or something?
Yes, the fluid always goes through the ABS block. From the master to the ABS/ESP module, then splits to the 4 corners. It acts as the proportioning valve in that sense also.
The ABS module has 16 valves that open and close to direct fluid where and when it's needed, along with a pump to create it's own pressure as needed. It can send or release pressure to any corner at any time, regardless of pedal actions.
In it's basic, unpowered, idle state, it's essentially pass-through. The pressure side valves are closed, and the release valves are closed, but the blocking valves are open. So on a new module, you could have air pockets behind some of the valves. Regular bleeding would work, but at the first ABS activation you could introduce more air into the main circuit. There is definitely a procedure during the initial startup that cycles valves and gets all the air out to prevent this. If you don't have a scanner, a couple good hard full-ABS stops, then re-bleed it, should do the trick.
Thanks for the info! So a regular bleed would only miss a very small amount of old fluid.
Any idea of the affects a higher viscosity fluid has on the system? I know a lot of people have mentioned using RBF 600, SRF etc.
I'm a dealer tech and we flush the cars every 20k, I've never noticed a change, even on cars that haven't been well serviced, in pedal feel. Me personally, I just run good OEM fluid but I don't track my cars so boiling points aren't really an issue. MB OEM fluid is a very good DOT4 fluid. I'd go to braided lines before I swapped fluids if pedal firmness is the goal.
#32
You're supposed to slowly pump the pedal while power bleeding. It helps quite a bit when you do.
I also believe the screens are the same for ABS/ESP or whatever as the SBC screens in the link I provided. There's a way to cycle abs pump while bleeding to flush it. It's the replace procedure.
#35
And as part of bedding the pads in I did not only slow downs but also ABS stops, but I did not rebleed
#37
I hear you but I change BF per the service manual which always seems to firm up the pedal feel. I have been doing it on 11 cars going back to my first W124 in 1987.
#38
So:
No ABS module
Our vehicle does not have SBC
Attachment 414817Attachment 414818Attachment 414819
The ESP module does have two functions that could be something.
One is the one that I was referring to yesterday.
The other is in case you ve replaced the unit.
No ABS module
#39
Joe, help me out, because thereโs nothing on the procedure.
So I have two controls
High pressure return pump and discharge valve.
I think the abs works based on a pump that build really high pressure. This is then released in order to counter the actuation of a wheel brake momentarily.
So possibly the cycle is that the emergency braking happens, the release valve releases counter pressure suspending the braking at the wheel that slips, then the high pressure pump rebuilds the high pressure in the high pressure accumulator.
So what would the bleeding be?
One actuation of the release valve, then one actuation of the high pressure pump then one actuation of the release valve ?
Then a bleeding session?
I mean actuating the release valve with the bleeder open may put a hole through the fender, no?
May be a really dangerous idea, right?
Who knows what kind of pressure weโre talking about .....2000 PSI?
#40
ESP is simply Electronic Stability Program, which incorporates ABS along with a pile of other functions, all used to keep the car pointing where you want it to go.
SBC (Servotronic Brake Control) was a system that did away with the conventional, driver generated hydraulic pressure, instead using sensors and servos to calculate the drivers desired braking power and a pump to generate pressure and apply the brakes as needed. Good idea in theory, but overcomplicated things unnecessarily and when it failed, the resulting lack of braking power was quite dangerous. That's why that system never stuck.
#42
Joe, help me out, because there s nothing on the procedure.
Who knows what kind of pressure we re talking about .....2000 PSI?
#43
I guess the feedback from customers was so bad, that they decided to make it go away.
Then in the E55 forums, the owners are worried about the cost for the replacement of the SBC unit. it seems they all fail at similar high mileage.
However, as a foot note, the new Giulia Quadrifoglio also comes with a brake-by-wire system and there has not been one review that I've read so far that criticizes its brakes.
Which to me means that there is a "second generation" SBC system that is going to be introduced sooner or later.
BTW the first attempts with funky brakes were by Citroen which wanted a central hydraulic system, for suspension, brakes, steering and so on. Those also did not modulate well..
