Underdrive/lightweight crank pulleys
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
Vivid Racing has the Agency Power underdrive crank pulley on sale for $480 from $600. Is this worth it? Are there pulleys that are reccomended over the Agency Power brand?
Thanks!
Thanks!
worth it compared to what? whistle tips? for $600 you are better off spending a little more and getting a tune. don't waste money on a pulley. the negatives far outweigh the maybe 5 whp you would get.
Underdrive pulleys are not a good idea on any car that uses any significant amount of electrical power, and our C63s have LOTS of electrical accessories. It can also adversely affect the effectiveness of your air conditioning compressor.
Having done an underdrive setup on a U.S. made car some time ago, I found the power difference was undetectable and the negatives were very evident. I would never do it again.
Jim G
Jim G
Thanks for the tips, I guess ill keep the stock crank pulley as this is my daily!
Shardul, do you also make a billet replacement idler kit like for the M113ks? I can't believe AMG is putting plastic pulleys on motors LOL!
I have an under drive pulley and have not seen any electrical issues with it. I've even tested the alternator and was just fine with a smaller crank pulley. I have the Agency Power and I think UPD has the evosport pulley.
I have a lightweight one on my clk. Car revs faster and picked up 13 whp when i dynoed 4 years ago. Id say post some dyno numbers but even with that you'll still find blind eyes and deaf ears and possibly still get told you're a fool.
The following 2 users liked this post by SactownP31:
CaptnCharisma (11-24-2017),
Infiniti (11-24-2017)
It definitely feels like it shifts faster and more aggressive when I get on it. Unfortunately I never did a before and after dyno with it. I did dyno last year and managed to get 475 whp with it, e85, ROW boxes and filters, tune, and a secondary cat delete so not bad numbers for not having long tube headers.
C63 507 AMG DA Car #19
Ud
There is a trade off when ud a crank pulley, but if you are ok w that then yes there is a sm hp inc.
however, going to be hard to detect 10hp on a 500 hp engine.
most spend that mod $. Elsewhere
So I've enjoyed having the agency crank pulley but I have hit a big snag due to it after rebuilding my engine. The under drive crank pulley does not have any markings for 40 degrees TDC so while trying to get the timing set there isn't really anywhere to reference other than where I took the cams off when I started tearing the engine apart. I've been able to get the engine in the ballpark and run but it sounds like a lawnmower. Off to the shop it goes.
Anyways if you get an aftermarket crank pulley you may want to get it the crank position etched on it during install.
The following 2 users liked this post by CaptnCharisma:
betrezra (12-13-2017),
Celicasaur (12-11-2017)
Jim G
I suppose your only alternative for now is to use an oem pulley to time it up and then swap the pulley back out again?
With the M156, the crank pulley doesn't have a harmonic balancer in it?
The only thing I would look into is what the M159 has. And that's easy enough with part numbers.
I'm pretty sure it does....nothing special really, but that hardened rubber certainly serves it's purpose I suppose.
I was considering the pulley for a good while myself tbh, but seeing as I'm going to raise the rev limit, i'll keep all the balance that i can get
