C63 AMG (W204) 2008 - 2015
Help finding a part - coolant hose plastic connector
Old Dec 5, 2017 | 01:32 PM
jaspirr's Avatar
C63
I'm looking for a rather generic Mercedes part but it doesn't seem to have a part number or anything. I have the part numbers of everything it connects to, I just can't get this one little piece.
It's a connector that links a coolant vent hose to the engine block. Here's the piece I need to replace (highlighted in red)
It's flimsy and plastic. It plugs this hose into the engine block The hose itself (highlighted green) is fine. It's just the connector into the block.
Half of the connector got stuck in the block:
It was threaded in there, I eventually got all the plastic pieces out.
One more picture for reference, here is the hose that it connects to the block. The part I need is not shown in this picture, and it should be where the red circle is.
Anyone know where I can get a part like this? It seems to just be a generic plastic connector piece. Unfortunately my car can't run without it.
Old Dec 5, 2017 | 02:18 PM
jaspirr's Avatar
C63
A bit more information. It plugs into the thermostat. See below:
http://cdn6.pelicanparts.com/catalog...030475-M22.jpg
Old Dec 5, 2017 | 02:35 PM
DavesMeanE's's Avatar
Former Vendor of MBWorld
93' 500E, 95' Corolla
It IS the thermostat...
Dave
Old Dec 5, 2017 | 02:37 PM
jaspirr's Avatar
C63
Dave
I just need that little black plastic piece on the top of the thermostat. I'd rather not replace the whole thermostat for a 20 cent piece of plastic.
Old Dec 5, 2017 | 06:00 PM
Mort's Avatar
GL with that. Buy the thermostat complete. You will not find the plastic connector piece separate from the thermostat.
Old Dec 5, 2017 | 08:33 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
You have to buy the thermostat to get it, only cheaper option is if you can get a used thermostat and remove it, but it may break the same trying to remove it.
Old Dec 6, 2017 | 01:04 PM
zcct04's Avatar
C63 coupe, Z3M Roadster garage queen
That's some very confident responses - sounds like several of our experts have learned this one the hard way!
Having to buy a whole new t'stat is understandably painful. I'm used to $20 for domestic cars. This one runs $100-$200. Maybe time to hit the junk yards - verify before you shop, but it looks like all the M156 engines use the same one.
Old Dec 6, 2017 | 01:06 PM
zcct04's Avatar
Or get a used t'stat and just install it in place of your old one - no need to remove the connector and risk breaking it.
Old Dec 6, 2017 | 04:32 PM
jaspirr's Avatar
C63
I had to buy a new thermostat. I reviewed it with the parts guy at the dealership and the plastic piece does not come out. So I paid $160 for a little piece of plastic,but I guess I got a new thermostat out of it too.
If anyone is so inclined, I think there are definitely ways to rig this up yourself. It's just a hollow piece of plastic. It connects the thermostat to an overflow tube. All you would need is a hollow plastic tube that threads into the same hole, and then a rubber hose that fits over that plastic piece. Not complicated but just not something I wanted to do yesterday.
Old Jan 23, 2019 | 07:04 PM
Rob23rr's Avatar
07 e63 Amg
hi im dealing with the exact same issue! How did you removed the left over plastic inside the hole ? And I wonder how I can make it work without spending $100+ on a thermostat. Thanks!
