Dyno Comparison: Stock/Tuned '09 C63 vs Stock/Tuned '13 C63 P31
To make things interesting, I also have the dyno files from my old 2009 C63 (also only had secondary cat delete) that had a V4 tune.
Same exact dyno, different cars, but same exact mods.
Quick shoutout to European Auto Source in Anaheim for helping me with this 'experiment' with their dynojet.
First dyno is my old 09 C63 stock vs Eurocharged V4 tune
Next dyno is my '13 C63 P31 stock vs Eurocharged V5 tune
Lastly is all four dynos together...
Final numbers are...
2009 C63 stock: 364/360
2009 C63 tuned: 413/371
2013 C63 P31 stock: 404/355
2013 C63 P31 tuned: 423/377
All in all, the numbers are as expected but its nice to finally see how all four compare on paper.
- SAE correction factor used (versus STD which would have inflated the results)
- SAE correction factor seems to be 0,99 for all 4 curves if I am reading the charts properly, so no weird distortions due to non-typical temperatures, barometric pressures, or humidity.
- Also pretty much what I would expect to see - no strange or unicorn results.
Nicely done.
Jim G
Nicely done.
Jim G
~20whp gain. Contact eurocharged and they might have some leftover units available at holiday pricing. V5 has a few benefits besides power. Most notably is the transmission blip.
For example, with the stock P31 tune, the power at the rear wheels doesn't hit 400 hp until 6100 rpm.
With the V5 tune, it hits 400 at 5600 rpm.
The engine appears to rev limit at about 7000 rpm (even though the P31 kit apparently enables revving to about 7200).
So, the rpm range in which the power meets or exceeds 400 rwhp has stretched from 900 rpm to 1400 rpm - an increase of 56% in the width of the powerband inw hich power at the wheels exceeds 400 rwhp.
This is a VERY significant benefit in acceleration scenarios.
This is because high performance engines always have a peakier powerband than more pedestrain engines, so you have to keep them in the rpm band in which they make good power. What hampers that effort is the need to keep the engine in that powerband via transmission gear shifting. When the engine hits the rev limit, you HAVE to shift to the next gear. But, that normally drops the rpm quite a bit - even with a 7-speed transmission - to an rpm where the power is normally notably lower. And, even with the short shift times of our C63 transmissions when in "S", or even better in "M", there is a brief interruption in power delivery.
You also have to shift DOWN more often when a powerband is narrower, in order to keep the power up.
By stretching the width of the powerband, you reduce the number of times you need to shift, AND you reduce the magnitude of the power drop when you do so on an upshift.
Furthermore, you have to put "small" power increases like this in perspective with other performance increasing features in the P31 and other packages. For example, the lighter wheels and lighter brakes reduce rotational inertia a small, but notable, amount, which improves acceleration AND handling.
The C63, like so many other high performance cars "picks up a bit here and bit there" and all the bits added together make for a transformed driving experience.
Intence clearly knows this stuff. And to his credit, he is not seduced by the more aggressive V7 tune which also unfortunately appears to stress the durability of the clutch pack in the transmission, and he particularly likes the exhaust burble of the V5 on downshift rev matching.
Hard to quarrel with any of that.
Jim G
Jim G
Jim G
Jim G
There's also a big difference in consequential costs in repairing an MB transmission versus say a GM transmission. I was able to handle the repair cost of a GM transmission when I destroyed one. Not so sure about whetehr I am willing to pay for rebuilding an MB tranny.
Jim G
Jim G
https://www.amsperformance.com/cart/...-upgrade.html/
It's also not a difficult job to swap them out.
Jim G
