Drag racing with FL C63
The guys that drag on a prepped track with their FL C63's.
Do you launch using the launch control function, or do you turn the traction control completely off and modulate the throttle yourself?
Received 2,845 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
No launch control it sucks. Heat tires well. Traction on Sport. Brake boost - floor the gas while standing on the brake - as soon as it hits 3k rpm release brake. That’s been good for 1.7x 60’ times on street tires for me and is good enough. My experience with TC off on street tires wheel hops like crazy and stresses the drivetrain more than I’d like - I’ve already broken one axle, no thanks again. Slicks same as above but TC off.
Thanks for the info Blkrokt.
I've only run on a unprepared track, and there was no traction. I tried launch control, and it was useless. Then I tried Sport mode, but I found the lack of traction made the car cut power as it always wanted to spin. I found TC off to be best on a unprepared surface.
I'm using Yokohama Advan AD08 semi slicks. Running for the first time on a prepped track.
Will try sport mode, and launching at 3k.
All manual. Hit the paddle about 500rpm before redline as there’s a lag. Sport+ tends to short-shift.
With Hoosiers my best 60' / et was in dyno mode & sport plus. I did some runs and tried both manual and sport +, with + giving the best et's. Next I'm going to try a quick brake boost to see if it helps.
Sorry forgot one other point. 24psi cold in the rear tires. And get them real hot.
I don’t know if it’s 3k exactly but it’s definitely more than 1500. Maybe 2500? You can’t do it for more than 2sec or so or else it will go into some sort of failsafe mode and bog flat on its face. So whatever it gets to when I floor the gas and count to one Mississippi is what I launch at. Sorry if it’s not more scientific.
The following 2 users liked this post by BLKROKT:
Celicasaur (12-25-2017),
Schulminator (12-23-2017)
BLKROKT (12-25-2017)
Will be giving this a bash tomorrow.
Nice.... I'll try this at the strip next time.
