C63 AMG (W204) 2008 - 2015
2012 MCT transmission clutch seems to "hunt" when at cruise speed
Old Jan 2, 2018 | 05:45 PM
Peter Konstek's Avatar
C63 2012 P31
Hi everyone
I was wondering if anyone else has noticed if their clutch on the MCT seems to "hunt". when i mean hunt, it seems to engage/disengage which is a bit like the old torque convertor going in and our of lockup. it mainly happens when at coast speed and very light throttle. if you load up a bit to gain speed or go up a hill it doesnt do it, its mainly when its coasting. it seems to do it in all gears and most speeds. Ive done the TCU reset, and it hasnt helped. Ive heard about some kind of clutch recalbration using star software, maybe it needs to be recalibrated?
Any advise would be greatly appreciated.
Pete
Old Jan 28, 2018 | 01:31 AM
C63 2012 P31
Originally Posted by Peter Konstek
Hi everyone
Pete
I took the car back to the dealer, as it had 3 months warranty. Ended up rebuilding the gear box free of charge.
Old Jan 28, 2018 | 04:47 AM
RZT5's Avatar
Edition 507 Coupe, M278 powered E550 Coupe, S211 E500
Have you driven it since? Did that cure the problem?
Old Jan 28, 2018 | 11:26 AM
Savage-wp's Avatar
2014 Mercedes C63 AMG 507 Edition
Glad to hear the dealer sorted you out.
How does it feel to drive now.
Old Jan 28, 2018 | 02:43 PM
Tlnt60's Avatar
2012 C63 AMG Coupe
I had the same issue with mine. Turned out to be the valve body. They replaced the valve body and solenoids. Haven't had a problem since.
Old Jan 29, 2018 | 05:36 PM
amgen's Avatar
C55 AMG T with Kleemann K2 and some stuff: 414 hp and 562 Nm :-)
It´s probably the PWM-solenoid you need to change in the gearbox.
Old Nov 14, 2018 | 07:38 AM
Amr_c63's Avatar
14 polar white E550
Bringing back an old thread !
iv been dealing with this issue for about 6 months now and its getting really annoying , partial throttle cruising in gear it seems to like engage and disengage like stated above . Full load the car holds the power fine , tranny flash has been done at MB also adaptions with star have been reset . Iv been reading about the MCT and it seems like the solenoids are going to be different on the board would all need to be replaced ??
Old Nov 20, 2018 | 01:02 PM
Amr_c63's Avatar
14 polar white E550
Bump some input from the ones who have fixed this problem would be appreciated !
Old May 6, 2025 | 06:46 PM
ZackaSnack's Avatar
2010 W212 E63 (M156)
Apologies to revive an old thread, but can anyone chime in on known fixes for this? I'm experiencing the exact same behavior on my 2010 E63
