C63 AMG (W204) 2008 - 2015
CV joint issue or just cold?
Old Jan 9, 2018 | 03:40 PM
agp423's Avatar
2018 GLC63
Whenever I just start my car and have my steering wheel turned all the way to either direction, I hear a loud bump/clicking sound from the front axle. However, whenever I'm pulling into tight spots after some driving, I hear no sounds even if I have my steering wheel turned all the way. Is this an issue with the car being cold, or a problem with CV joints/axle? What additional diagnoses can I do?
Old Jan 10, 2018 | 12:02 PM
deadlyvt's Avatar
2010 C63 AMG
There is no cv joints on the front axle, unless you have an all wheel drive non c63
clicking as you describe would most likely come from a wheel bearing
Old Jan 10, 2018 | 02:15 PM
agp423's Avatar
2018 GLC63
So... wheel bearing or just cold?
Old Jan 10, 2018 | 04:11 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
A "loud bump/clicking sound from the front" is NOT normal no mater what the temp is outside.
Old Jan 15, 2018 | 02:24 PM
agp423's Avatar
2018 GLC63
Took it to two different shops, both said it's nothing. It's the wheel tilt when the steering is all the way plus really cold tires rubbing the inside of the wheel arch. One shop that services Lotuses too says they see a lot of those with Lotuses as well.
Old Jan 15, 2018 | 09:00 PM
ec_nova's Avatar
E300, C63
yep all AMG's I've ever driven do it in cold/wet weather, especially with summer tires. perfectly normal
Old Jan 15, 2018 | 09:33 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Mine doesn't do that.
Do you have aftermarket rims with aggressive offset or over-sized tires on it? Shouldn't rub the fenders from factory...
Old Jan 16, 2018 | 06:04 AM
ec_nova's Avatar
E300, C63
who said anything about rubbing fenders? The tires skip on the ground. Mb even has a bulletin out about it saying it’s normal
Old Jan 16, 2018 | 06:11 AM
agp423's Avatar
2018 GLC63
No, stock wheels and suspension parts.
Old Jan 16, 2018 | 06:12 AM
agp423's Avatar
2018 GLC63
Can you link us please
Old Jan 16, 2018 | 08:01 AM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
“Tire skip” is totally normal and common on cars with wide front tires. It’s geometry. That’s probably what you’re hearing/feeling, mine tends to do it more in parking garages (or painted concrete) when the tires are hard as hockey pucks like they probably are now. (when tires are nice and warm and squishy you’re just not going to notice it as much)
https://www.corvetteforum.com/forums...rol-issue.html
Theres a good pdf describing this floating around out there on one of the Corvette forums but I can’t find it right now.
Old Jan 16, 2018 | 08:31 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
The OP did...
Old Jan 16, 2018 | 11:50 AM
agp423's Avatar
2018 GLC63
The OP did...
I think ec_nova was just saying it's normal... We all get it now. Besides, me being mis-informed about rubbing does not substantiate any positions based on my mis-informedness.
