C63 AMG (W204) 2008 - 2015
c63 19" w205 wheels on W204 pics
Old Apr 18, 2021 | 05:43 PM
  #51
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
Similar to the 18's on the FL W204 but in 19" and 1/2" wider front & rear.
Also better front ET38 and similar rear ET56.
Old Apr 18, 2021 | 06:44 PM
  #52
1Solo1's Avatar
2014 C63 AMG 507
Exactly!!
Old Apr 18, 2021 | 06:46 PM
  #53
1Solo1's Avatar
2014 C63 AMG 507
Just FYI... I used a small (10mm, I believe) spacer in the rear.
Old Apr 18, 2021 | 07:53 PM
  #54
Cwagon's Avatar
What size tires are you running?
My current 275/30 rears would have rubbed with anything more than 4mm spacer that gave me overall ET50.
Old Apr 18, 2021 | 08:15 PM
  #55
1Solo1's Avatar
2014 C63 AMG 507
Front: 245/35
Rear: 265/30...initially I ran 265/35s but on occasion they would scrub.
***Need to clear this up...this was the setup I was running up to about two months ago. I have since removed the 19” wheels/tires, put the factory 18s back on and sold the car.*** Picked up a 507 but I do miss the 2013.
Old Apr 21, 2021 | 07:25 PM
  #56
djr48312's Avatar
2009 c63
Hows the ride on the coil overs? Is there a weight reduction vs factory spring and shock combo? Are your coil overs adjustable? Occasionally i feel it would be nice if i could make the ride a little less bone jarring.
Old Apr 30, 2022 | 10:30 PM
  #57
Bayareac63p31's Avatar
c63
hey were you able to use the TPMS that was on the rim with your car? tire shop is saying i need new ones.....Thanks in advance
Old Apr 30, 2022 | 10:55 PM
  #58
kavik's Avatar
Veteran: Army
2013 c63
I was able to use original tmps sensors but the batteries do wear down over time...
Old Sep 13, 2022 | 04:21 AM
  #59
Whodini's Avatar
2012 Mercedes-Benz C63 AMG Performance Package (Coupe)
Originally Posted by A///MG_Power
Looks great! Any rubbing at all?
Looks good.
I just put the exact same wheels on my 204 coupe. However, I was unable to install the centre caps on the rears because the stock lug bolts are sticking out too much. Did you have to alter them or change them out? Any info detailing that would be great.
Cheers
Old Sep 13, 2022 | 04:26 AM
  #60
Whodini's Avatar
Originally Posted by Cwagon
Yes they will fit with out spacers especially if running stock 235/255 sizes.
Here are a few phone pics of mine with the stock W205 tires 245/35x19 & 265/35x19.
I was running spacers in the pics 3mm front & 4mm rear but have since removed the front ones and fitted them on the rear.
I had a slight rubbing on front when negotiating a big dip at speed 100kph+ on a country highway.
Otherwise no rubbing at all.
Looks good.
​​​​​​​I just put the exact same wheels on my 204 coupe. However, I was unable to install the centre caps on the rears because the stock lug bolts are sticking out too much. Did you have to alter them or change them out? Any info detailing that would be great.
Cheers
Old Sep 13, 2022 | 05:48 AM
  #61
Cwagon's Avatar
The different seat depth front to rear is because the rear wheel has a shallower boss so lug nut doesn't sit as deep.
You may need to fit lug bolts from the W205 as they may have a shorter head length.
I'm running studs on mine and did have a length problem with my original dome nuts but have since fitted open nuts.
Old Sep 13, 2022 | 07:17 AM
  #62
blurred's Avatar
2013 C63 P31
Originally Posted by Whodini
Looks good.
Cheers
Sounds like you might not have oem lug bolts? Mine fit just fine, no issues. Pics?
Old Oct 3, 2022 | 11:03 AM
  #63
DaveSummer's Avatar
C63
Hey Benz, so these wheels are 19” on all 4 corners, stock W205 sedan wheels is that correct?
did you end up trying a slightly wider rear tire to get a more flush fit?
Old Oct 3, 2022 | 11:18 AM
  #64
blurred's Avatar
2013 C63 P31
His car looked lowered and either added alot of camber or stretched the image to make it look that way.
My specs are as follows and fit just fine, there is a little more room.
Wheel specs, from w205 c63s sedan
19x8.5 et+38 front
19x9.5 et+56 rear
Tire specs
Michelin Pilot Sport 4S
245/35/19 front
275/30/19 rear
