C63 AMG (W204) 2008 - 2015
Exhaust and air intake
Old Mar 17, 2018 | 09:06 AM
spudsAMG's Avatar
AMG C63
Hi
Whats the best after market exhaust and air intake you have found to give out the best power results?
Old Mar 17, 2018 | 10:01 AM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Wow, @BLKROKT is usually quicker at answering these questions - hold on he will get to you.
Old Mar 17, 2018 | 10:33 AM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
I give up
Old Mar 17, 2018 | 10:39 AM
spudsAMG's Avatar
AMG C63
?? So what is it
Old Mar 17, 2018 | 11:37 AM
BLKROKT's Avatar
Old Mar 17, 2018 | 11:42 AM
Funkwagen's Avatar
2009 C63 AMG, 2010 C250 4Matic Sport
An ECU tune
Sick AF's Avatar
'12 C63 Coupe
Hahaha
Originally Posted by BLKROKT
I give up
it's a never ending battle, but you've put up a good fight
Old Mar 17, 2018 | 11:57 AM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
MBH Motorsport or America Racing for headers. As far as intake they are very expensive for very marginal gains. I think the Renntech CF airboxes set the benchmark tho.
Old Mar 19, 2018 | 10:38 AM
Gsrchris's Avatar
Weekend/Project - W204 C63.
RENNtech intake's available if you are interested:
https://mbworld.org/forums/c63-amg-w...take-m156.html
Will include brand new air filters for free.
Old Mar 19, 2018 | 10:47 AM
Doc Oc's Avatar
2013 c63 amg dev pack
While headers seem to be the popular choice around here you can get similar gains for about half the price by going with upgraded log manifolds and fully catless mid-pipes. I gained 36 rwhp with that combo and spent less than $1500. I wouldn't waste a lot of $$ on an intake, unless you've got cash to burn. Row boxes and filters are fine.
Old Mar 20, 2018 | 06:00 AM
Celicasaur's Avatar
W212 - E63 AMG
On that note, I'd really like to see a back to back comparison (which will never happen, i know) of a decatted car vs long tubes decatted. I'm told that long tubes add more power before the peak power point but from what I see on separate cars with either a tune and headers or a tune and a decat...the figures and shape of the curves seem the same
Old Mar 20, 2018 | 09:09 AM
Doc Oc's Avatar
That would be very interesting. Funny thing is, over on the m3 forums there are several big threads on this same topic. Most of the guys over there just do catless x-pipes or test pipes, and they swear they make the same power as arh long tubes because of the good design of the OEM manifolds. Arh claims otherwise but catches hell for it as they haven't shown much proof. Nick from arh and a few guys over there have been going back and forth on the topic for several years.
You've gotta think there's more area under the curve with LT's vs logs, but I'm certainly not switching to find out That was not a fun install.
Old Mar 20, 2018 | 10:23 AM
skratch77's Avatar
2005 E55
I have a dyno of my car from just adding headers and keeping same tune on the car. The only thing changed was adding headers. It picked up power only past 5500 rpms so before you all waste 5 grand doing headers I would just do a second cat delete and call it a day.
The bmws have headers installed stock and is why they dont make more power adding them.
here is the dyno on 24 deg timing...same tune etc.The only difference new plugs and new coils as you can see how smooth the curve looks after with headers.On 28 deg timing I would guess 475-480whp but I hit a deer before getting back on the dyno to test new tune.
Old Mar 20, 2018 | 10:47 AM
Doc Oc's Avatar
This is my before and after
Old Mar 20, 2018 | 12:05 PM
carid's Avatar
PREMIUM SPONSOR
Mercedes E55 AMG E211
I can suggest checking out the exhaust for C63 made by Akrapovich:
Akrapovic® - Evolution Line Titanium Exhaust System
Specs:
Exhaust Tubing Material: Titanium
Exit Location: Quad Rear
Exhaust System Sound: Aggressive / Loud
Max Power Stock: 447.9 (HP Imperial) / 454.1 (HP Metric) / 334 (kW) / 6400 (Rpm)
Max Power Akrapovic: 456.6 (HP Imperial) / 463 (HP Metric) / 340.5 (kW) / 6280 (Rpm)
Max Power Increase: 11.6 (HP Imperial) / 11.8 (HP Metric) / 8.7kW) / 3550 (Rpm)
Max Torque Stock: 442.5 (Lb-Ft) / 600 (Nm) / 4370 (Rpm)
Max Torque Akrapovic: 453.1 (Lb-Ft) / 614.3 (Nm) / 3720 (Rpm)
Max Torque Increase: 16.4 (Lb-Ft) / 22.3 (Nm) / 3720 (Rpm)
Weight Stock: 86.9 (Lb) / 39.4 (Kg)
Weight Akrapovic: 44.3 (Lb) / 20.1 (Kg)
Weight Decrease: 42.6 (Lb) / 19.3 (Kg) / 49 (%)
DYNO is available here
Old Mar 21, 2018 | 08:06 AM
Celicasaur's Avatar
W212 - E63 AMG
I wonder if its something that requires a more aggressive cam to make the most of the better outflow I know that on my celica a decat is worth 5hp...decat with long tube is 15hp but then it does have an angry vtec cam above 6k rpm...who knows
So your before graph was with just secondaries out or were the primaries out also? It really needs to be a full decat (like longtubes) to come to any conclusion...still...better than nothing to see your graph. I think mine picked up 40 from just headers too with a canned V6 tune.
Yeah they're certainly miles better in stock form than our pathetic log manifolds.
Hmm this could be a task if anyone's bored at work...fish out threads of full decats vs headers
That's stock vs headers and tune....?
Again....be nice to see full decat vs headers and on the same tune
Specs:
Thank you for spamming this pointlessly hi-jacked thread with something even more irrelevant
Old Mar 21, 2018 | 08:26 AM
skratch77's Avatar
2005 E55
My before dyno was all stock exhaust and both cats and the after dyno is with headers and 200 cell race cats.
my next dyno will be with adding a remus exhaust and more timing.
Old Mar 21, 2018 | 08:38 AM
Doc Oc's Avatar
No, the before run is tune only, after is with the manifolds and cat pipe. Never dyno'd stock unfortunately.
Old Mar 21, 2018 | 09:10 AM
Vladds's Avatar
2010 C63 2019 GLA45
So headers, all 4 stock converters removed and replaced with only two 200 cell race cats.
What do long tubes do with 4 stock converters? Of course there would be no room to have 4 stockers. And if you do this with short headers and they pick up very little, people say it's because of the length of the headers...
In a way, lth are probably not even loud, it's the removal of all 4 converters and only having 2 race converters or none, that is loud.
Too bad nobody makes short headers anymore.
Doc, what HP are the PLM logs good for, with all 4 stock converters?
Old Mar 21, 2018 | 09:34 AM
Doc Oc's Avatar
I've never dynod with just the plm's. Did the headers and cat pipes at the same time. From my research on this site though it looks like they're good for about 14 rwhp by themselves.
