C63 AMG (W204) 2008 - 2015
C63 Oil leak. Advice/Help Needed. TIA
Old Mar 25, 2018 | 05:13 PM
jordan.jld's Avatar
c63
Hello everyone,
Need some advice/help pls.
2008 C63 with approximately 130,000 kms
- had an independent shop that specializes in MB replace my Headbolts/buckets last September 2017 right before I stored the car for winter. After I picked up the car I drove it for approximately 500 kms and stored the car. I start and run the car couple times a week to while being stored.
- early February weather was nice and warm so I decided give the car a good detail and perhaps an oil change and noticed the theres quite a bit of oil leak on the bottom pan.
- Took it back to the mechanic and they said it looks like its the Valve cover and was advised that they replaced the gaskets and got the car back and brought the car back again for storage.
- Today, I was motivated to do my own oil change and found this again on the bottom Pan. Messaged the Shop again and just waiting for their reply.
Pics
it seems that the oil is coming from the front passenger side coming from the top. Im not sure if it is engine oil or steering fluid either.
Thanks again Fam,
Jordan
Old Mar 25, 2018 | 06:28 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Unless it's smoking quite a bit from the engine bay it's probably not the VC.
It's more likely engine oil coming out of the upper oil pan gasket. It's some what common.
Old Mar 25, 2018 | 07:15 PM
jordan.jld's Avatar
c63
there was quite a bit of smoke coming out initially, also the leaks seems like its even above the power steering pump. Praying its now upper oil pan.
Old Mar 25, 2018 | 07:20 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
If there was smoke then probably the VC gasket because it drips down over the EM which is a hell of a lot easier to fix than the upper pan gasket. You need to remove the engine to get at that one.
Old Mar 25, 2018 | 07:37 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Don't pray for that, expensive pain in the *** fix - VC gasket is super easy in comparison.
Old Mar 28, 2018 | 05:14 PM
jaimejrivera's Avatar
2012 C63
I had a similar situation. Turned out to be the gaskets from the cams adjuster cover. Fix it myself; it take 2 to 3 hours working at a slow pace. Gaskets are like 12 bucks for both sides.
Old Mar 29, 2018 | 11:34 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
I would say that it's most probably the Valve Covers or the Cam Housing Adjuster Housing gasket that are leaking. I had a similar issue as yours, and after the valve covers gaskets replaced, we discovered that it was actually the cam adjusters housings that were leaking. Also check to see if its the oil cooler return lines, that run into the drivers side of the engine block, as these o-rings do go bad. Ask me how I know.
Old Jun 13, 2018 | 12:33 AM
kikokiko1976's Avatar
2007 cls 63 AMG
Do you have a diy for the removal and replacement for camshaft adjuster gasket?does it still need to be timed before removal of the camshaft covers?
thank you
Old Jan 6, 2020 | 07:35 PM
Airspeed1's Avatar
2011 c63
thank you
anyone willing to share a DIY on replacing these seals
