ROW airbox install problem.
I keep having an issue with the left ROW airboxes (passenger side). I have reinstalled it at least 6 times, and always seems to have a little gap no matter how many times i force the airbox into the tube housing. Please see photo for reference. I have patiently reinstalled it 6 times over the past 3 weeks and every time it doesn't seem to fit in perfectly like the right side. Also when i tighten the housing, it eventually squeezes out the airbox and i can tighten on and on and on and doesnt seem to tighten up. I mean... is it just me getting unlucky? Any advice will help. Thanks.
Right side
Right row box. very tight and securely installed
Left side (passenger side)
As you can see. Doesnt seem properly secure.
Thanks!
https://mbworld.org/forums/c63-amg-w...valve-diy.html
Best advice possible....has been the only way I reinstall mine for a pretty good while now
thank you for the response!
If you are not in far enough when you tighten the clamp it will start to push the lid forward and clamp will slip off and just squish the tube as it has nothing to clamp to.
Like others have said take off the Y pipe if you keep having issues and see if you can get it all the way on and then snap the y pipe back on after attached.
