C63 AMG (W204) 2008 - 2015
Android Widescreen touchscreen For W204
Old Jun 22, 2018 | 12:51 PM
  #101
Damir85's Avatar
C63 2011
Originally Posted by LoFox
oh wow, that's pretty harsh ... so it sounds like if you attempt to use the warranty, they might/will not give it to you and then they don't want to do business with you further.
I just want what i paid for
Where does it state on page that you have to reboot original unit every single time ?
It dosent
Only if you have FL then it will work great
Old Jun 22, 2018 | 01:01 PM
  #102
LoFox's Avatar
C63
It dosent
In your case what is the behavior you're seeing vs what should be expected? You turn on the car and then what do you need to do to the COMAND unit? (I might be in the same boat when mine arrives since my C is pre-facelift, although I might have a different aftermarket model display and SOC)
Old Jun 22, 2018 | 01:25 PM
  #103
Damir85's Avatar
C63 2011
Yeah my behavior, if i pay 500usd i want it to work
Your be will the same as mine
Just hold the ON button when you start your car
Old Jun 22, 2018 | 02:00 PM
  #104
LoFox's Avatar
C63
So the issue you have is that if you don't hold the ON button while the Android display is booting (when the car is just started) then you won't be able to see/access to OEM pass-through UI from the stock COMAND? Do the speakers work, or is the system totally useless without using the hold-ON-button trick at startup?
Old Jun 22, 2018 | 04:18 PM
  #105
Damir85's Avatar
C63 2011
The speakers work but you wont be able to see the original interface unless you hold the ON button
Old Jun 22, 2018 | 05:11 PM
  #106
LoFox's Avatar
C63
I'm curious if COMAND would behave differently if we uninstall the COMAND display with the system in an ON state, ie:
1. With the factory display system installed
2. Turn the ignition to ACC
2a. Press ON if COMAND doesn't turn on automatically
3. COMAND and factory display should turn on with the display opening up on pre-FL models
4. Turn the ignition to OFF
5. COMAND display closes and unit powers off
6. Uninstall factory display and replace with Android unit
Seems like maybe a bit of a stretch, but who knows :-/ .... The only thing that made me think of this is if you power off the COMAND display while the car is on and then turn the car off, the subsequent time your turn the car on the COMAND unit will be off and you'll need to manually press ON to turn COMAND on.
Last edited by LoFox; Jun 22, 2018 at 05:12 PM. Reason: extra clarification on verbage
Old Jun 27, 2018 | 10:50 PM
  #107
LoFox's Avatar
C63
My Android display arrived today, presumably running Android 7.1. An mentioned earlier in the thread, shipping took 3 day, originating in Hong Kong. I'll try to install it this weekend and let you know how it works in my pre-FL C63.
Old Jun 28, 2018 | 11:31 AM
  #108
bbbbbbb's Avatar
2013 benz c250
could you make a YouTube video of your install and function of your new screen?
So we all can see if the improvements had we been applied?
Old Jun 28, 2018 | 11:49 AM
  #109
LoFox's Avatar
C63
I probably won't make a YouTube video of the install but I'm more than happy to write up a detailed install guide with photos and marking (same level of detail as my other install DIY posts here.) I can make a video of the usage and functionality once the display is in though.
Old Jun 28, 2018 | 11:53 AM
  #110
bbbbbbb's Avatar
2013 benz c250
Cool, a video of its functions would be good. This way we can see if the issues reported have been addressed.
When you do make the video, could you post the link or your channel name so we can go watch it, please?
Thanks.
Old Jun 28, 2018 | 12:01 PM
  #111
LoFox's Avatar
C63
Thanks.
Yes, will do, I'll post the link here, I hope to get around to installing it with 1-2 weeks.
(currently I'm having an MBH full exhaust installed and ECU reflash done, the powder coating of the headers is taking the longest time so far.) [/offTopic]
Old Jun 28, 2018 | 07:54 PM
  #112
GRP's Avatar
GRP
2010 C63 and 2018 GLC63s
Sitting on the fence here - please keep the updates on install and use coming.
Old Jun 30, 2018 | 02:53 PM
  #113
LoFox's Avatar
C63
The shop that's installing my exhaust is having an impossible time, so the car most likely won't be ready until the week of July 9th (they had pull the exhaust manifold studs out of the block to get the headers placed in position, and that's only on the passenger which is considered the easier side.)
Assuming no further delays I should be able to install the new display on the 14th or 15th and make a video along with a write-up.
Old Jul 1, 2018 | 05:09 PM
  #114
HorseSchnoz's Avatar
2013 C63 AMG P31 Coupe
Looking forward to your video LoFox. I just ordered this for my facelift C63 and my first install attempt did not go so well. Everything went smoothly until I came to the part where I had to put the Comand unit back in after the new harness was connected up. I could not for the life of me get it to go all the way back in; no matter what I did with the new harness it always seemed to be in the way and the Comand unit would stick out about 2" from where it should sit. I'm wondering if anyone who has installed this unit on their facelift C63 would have nay advice for me as it was incredibly frustrating that something so simple ended up causing me to revert back to stock for the time being.
I will say that I did turn on the new unit after it was hooked up and the display and UI were quite nice. The screen has a nice sharp resolution and moves fluidly with your finger with no signs of lag at all, and was able to seamlessly connect to my WiFi and bluetooth. The only issue I noticed is that the old Comand screens looked all messed up, so I will definitely have to play around with the resolution settings if I decided that I want to use those screens at all in the future.
I'm probably going to end up paying an audio shop to install it at this point as I spend so much time away at work as I do on days off so my free time is worth more than my money.
Old Jul 2, 2018 | 08:19 AM
  #115
jptaylor's Avatar
W213 E63S Wagon, W204 C63 P30(RIP), WK1 Grand Cherokee SRT8(RIP)
i have been through mine top to bottom and it is awesome. I am sending my first screen back for the company to inspect today, not that i had any issues with it but i did lots of logging and testing for them in vehicle and they want to see the logs. No issues on my end and i have no idea what the "press and hold ON" is all about, when i installed mine it was plug in last connector, turn on ignition, boom, done.
Old Jul 14, 2018 | 08:46 PM
  #116
Honro's Avatar
2011 C63 AMG P31
FYI the new unit with the updated hardware AND software (android 7.1.1) is now available from CKM and can be seen on his website. In addition he has added MPH & Fahrenheit for the US. Ive ordered mine & should hopefully have it next week.
Old Jul 14, 2018 | 10:17 PM
  #117
SatelliteMan's Avatar
2009 C63 AMG Sedan
Nice...So this is what we've been waiting for right? Can I confidently buy without bugs and have it work decently?
-STeve
Old Jul 15, 2018 | 06:42 PM
  #118
Honro's Avatar
2011 C63 AMG P31
-STeve
Yes its the update we have been waiting for. What I do know is he spent an extra month testing & adding (according to Chris) extra functions then the one available on ali express. So when I receive & install mine, i can report back. But how confidently can you buy anything aftermarket off the web these days heh.
Old Jul 15, 2018 | 09:11 PM
  #119
2009 C63 AMG Sedan
Yeah we'll see. Let me know how it goes. Anything is an improvement from the 1st release.
Old Jul 16, 2018 | 07:05 AM
  #120
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Ordered from CKM last night. Will report back on the install.
Old Jul 17, 2018 | 05:04 PM
  #121
Silversun262's Avatar
86 Targa, 91 560SEL, 06 E55 Estate, 13 C2S, 21 MACAN GTS, 05 R6 Track, 15 R3 RACE BIKE
Anyone installed this with the Apple Car Play Dongle?
Old Jul 17, 2018 | 06:01 PM
  #122
Crya's Avatar
2009 C63 P30
Is the screen compatible with iOS iPhone? It just needs a hotspot connection is my understanding but haven't really seen any "pairing/connection" info, just the hardware installs so far.
Old Jul 17, 2018 | 06:07 PM
  #123
TPete19's Avatar
2010 C63 AMG, 2010 GLK350
I would hope that it would tether using the Bluetooth connection rather than requiring you to switch your phone's mobile hotspot on as well.
Old Jul 17, 2018 | 11:39 PM
  #124
Ludedude's Avatar
2014 C63 Coupe
Really interested to get your feedback. I’m curious about real world reporting from a trusted source on how the FL option looks and works, especially since you appear to lose the glare shield of the original in dash display.
Did you buy the OBD2 interface?
Old Jul 17, 2018 | 11:40 PM
  #125
Ludedude's Avatar
2014 C63 Coupe
You can use BT for streaming but you need the hotspot on to use maps or anythIng else that needs data to function.
