C63 AMG (W204) 2008 - 2015
ARH Headers installed and have some rattles HELP
Old Apr 25, 2018 | 08:40 PM
nardobenz's Avatar
2014 C63 AMG
Got my car back from the shop with the installed ARH headers and v7 tune. Car sounds amazing, but there is this weird rattle/vibration I am getting when I floor it. The throttle pedal at like 3-4k rpm vibrates pretty bad--pretty sure its not supposed to do that. Any thoughts?
Old Apr 25, 2018 | 11:35 PM
Amr_c63's Avatar
14 polar white E550
What your experiencing is “NVH” , the headers might be hitting the subframe or a part of the car which then will vibrate into the cabin . Check to see if any of the pipes are resting or touching any part of the car underneath and either adjust the section off the manifold itself or if it’s a design flaw just simply pry between contacted area till there is no contact .
Old Apr 26, 2018 | 07:48 AM
East Coast Euro's Avatar
Former Vendor of MBWorld
C63 and CLK55
It sounds like they may be contacting at wide open throttle. Check the clearance and make adjustments if possible. Also check the condition of the engine mounts. Hopefully it's an easy fix
Old Apr 26, 2018 | 11:59 AM
I am Jeff's Avatar
Steel Grey Metallic C63!!
Look up my ARH header install thread. You have to retighten the clamps and add spacers to your cross bar. You need to add a half inch spacer to the cross bar. The rattling you're hearing is the pipes hitting the cross bar.
Old Apr 26, 2018 | 02:15 PM
Silversun262's Avatar
86 Targa, 91 560SEL, 06 E55 Estate, 13 C2S, 21 MACAN GTS, 05 R6 Track, 15 R3 RACE BIKE
Happy to hear this isn’t just my problem but sorry that it is affecting more people. It took me several days of adjusting and even cutting a half inch off one side of the x pipe before I got mine sorted from a vibration stand point. And I still have a small rattle and the tips stick out too much.
I would take take it back to the shop that installed it. If possible.
Old Apr 26, 2018 | 02:28 PM
Savage-wp's Avatar
2014 Mercedes C63 AMG 507 Edition
This.
I had to put spacers under the cross bar as well when I fitted IPE headers and mid pipes.
No rattles after that.
Old Apr 26, 2018 | 02:34 PM
nardobenz's Avatar
2014 C63 AMG
I don’t think it’s the cross bar, I think it’s the header touching the heat shield... I can hear the engine idle and belts and pulleys inside the cabin clear as day like it’s pumping the sound through the speakers. I’m going back to the shop late today to sort it out.
Old Apr 26, 2018 | 02:43 PM
Savage-wp's Avatar
The headers do run close to the heat shields. Get the installer to check the clearance.
Old Apr 26, 2018 | 03:23 PM
I am Jeff's Avatar
I had to "massage" my heat shields with a hammer. I never had rattling up front.
Old Apr 26, 2018 | 04:34 PM
NotABaller's Avatar
2012 C63, 2014 E550
My heat shields also came loose and rattled. This was before I got headers installed but I imagine its a pretty common issue on our cars.
Old Apr 26, 2018 | 04:42 PM
I am Jeff's Avatar
Nope. I've never had my heatshield rattle or come loose.
Old Apr 26, 2018 | 07:39 PM
nardobenz's Avatar
2014 C63 AMG
So we fixed all the issues.
Throttle pedal vibration was coming from driver side bracket touching the O2 sensor.
Vibrations/sounds were fixed from putting the spacers on the cross bar, and playing with the foil heat shield. It was rubbing pretty bad.
Thanks for for all the help.
Old Jun 1, 2018 | 04:06 PM
Curious what you used for spacers. Thanks in advance.
Originally Posted by Savage-wp
This.
Old Jun 2, 2018 | 01:54 PM
Savage-wp's Avatar
I turned up 2 aluminum spacers in my workshop. I think I made them 15mm thick.
Then used a new bolt which was 15mm longer.
Old Jun 2, 2018 | 04:51 PM
only 2? I thought the bar goes the width of the bottom of the car.
Old Jun 3, 2018 | 12:34 AM
ShaneN.'s Avatar
2018 e63s edition 1
You running stock resonators and mufflers? Catless x pipe? I'd love to hear how it sounds.I just ordered ARH.
Old Jun 3, 2018 | 01:55 AM
Savage-wp's Avatar
It's not the entire width of the car, but most of it.
But, it only bolts on at 2 points, one on either side of the car.
I did this quite some time ago. It's possible it was 2 points on either side, in which case we turned up 4 spacers.
Old Jun 3, 2018 | 09:23 AM
I am Jeff's Avatar
There are 2 mounting points on each side, so a total of 4 spacers is needed.
Old Jun 3, 2018 | 09:36 AM
Savage-wp's Avatar
Thanks for confirming, I was going to slide under the car to confirm.
Old May 5, 2019 | 07:22 PM
jemnoriega's Avatar
2014 C63 AMG Coupe 507 ED
Where would I buy the spacers?
QUOTE=I am Jeff;7440028]Look up my ARH header install thread. You have to retighten the clamps and add spacers to your cross bar. You need to add a half inch spacer to the cross bar. The rattling you're hearing is the pipes hitting the cross bar.[/QUOTE]
Old May 6, 2019 | 02:27 PM
Mort's Avatar
If you can't find spacers you can stack up the correct size washers and get longer bolts to lower the bar so that it doesn't interfere, if that is the source of the vibration. There are four bolts attaching the bar to the chassis, two on each side.
Old May 6, 2019 | 03:09 PM
bhamg's Avatar
C63 AMG
A useful discussion:
https://www.engineersedge.com/wwwboard/posts/11506.html
