2013 C63 High idle issue
2013 C63 AMG
I’ve noticed this high idle issue the last few weeks with my 2013 c63. I searched and saw a few threads and none are the same issue as mine. I have no CELs but after driving for 45min+ when stopped my idle raises to 900-1000rpm and stays there(normal idle is 600ish). So I’m at the dealer and they have a shop foreman test driving the car but can’t get the issue to happen. Any ideas what this could be? Only other thing I’ve noticed is that my car has been running cooler than usual lately but I could just be paranoid with this new problem I’m not sure.
Was this the only time? I've noticed that a couple of times when I've started the car and rolled off immediately a bit more aggressively then the idle has been high when coming to a stop and the throttle was also more sensitive than usual. After I noticed this I restarted the engine and then slowly pulled off and it was fine after that. Not sure what has caused my issue, but maybe they are linked with your problem?
2013 C63 AMG
2013 C63 AMG
Dealer apparently tested for vacuum leaks doing a smoke test. I just feel like I would have a code if it were that or any other vacuum leaks. I also don’t get how it’s not throwing a code from idling high like that. I’ve seen there are codes for idling high.
Here is a video after I just got it back today. Of course the dealer couldn’t recreate the problem but when I get it I can.
https://youtu.be/AkHt1Fi4-X8
