C63 AMG (W204) 2008 - 2015
air bag warning lights help
Old May 1, 2018 | 04:14 PM
ceesixthree's Avatar
2012 C63 AMG Coupe P31 Magnuson Super Charged
After supercharger install on engine start warns of air bag malfunction. Any ideas. Bit vague I know but from another magnuson user maybe? Sorry all info I have at moment.
Old May 1, 2018 | 09:17 PM
Mort's Avatar
You will need the dealer or Star/Xentry to reset the error or determine what the issue is.
Go over your install and see if maybe you disturbed an electrical connection for the SRS. If the battery was not unhooked a SRS code can be set even if the system is operating properly.
Old May 2, 2018 | 07:15 AM
Thank you for your help mate I'll do so.
Old May 3, 2018 | 09:20 AM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
+1. It's completely unrelated to the supercharger installation and very likely a result of a temporary disconnection of some SRS connector during the s/c installation if the battery was left connected.
Old May 3, 2018 | 10:14 AM
It is related by them doing what you said most likely. I didn't have the warnings before so it's related some how.
Thanks for replies
Old May 3, 2018 | 10:21 AM
DPUDERER's Avatar
98 TC
Once you scan the system and get the fault code then you will know where to look.
There are inertia sensors under the hood or bumper that may have been disturbed.
Old May 3, 2018 | 10:23 AM
DPUDERER's Avatar
98 TC
It may just be a matter of clearing the fault code with a scanner. Often times even though the fault is no longer present the warning light will stay on until the fault is erased.
Old May 3, 2018 | 06:59 PM
Thanks mate, it doesn't have the light on it is only when I start car it reads on the cluster lcd display *irbag malfunction for right and left sides.
I'm getting a head restraint fault code too I just scanned this morning but I can't reset anything just read dtcs
Old May 3, 2018 | 07:01 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
You don't need Star/Xentry to reset SRS. Any scanner than can read the individual modules should be able to do it.
