C63 AMG (W204) 2008 - 2015
LARGER INJECTORS FOR W204 C63 AMG
Old May 29, 2018 | 02:08 PM
Jaideep Singh's Avatar
2009 C63 AMG
Exclamation LARGER INJECTORS FOR W204 C63 AMG
Hello All
After reading so many threads at this forum I finally bought a 2009 W204 C63 AMG. I am planning to go E-85 on it but currently looking for larger injectors that would fit in our engines. Could you please help me find such injectors. Also could you explain what kind of connectors a stock vehicle has on both engine/injector side. I was looking online the injectors with high flow have different connectors. Is there some connector terminology I can read to understand which connector would fit our engine?
Is there any marketplace kind of forum for buying used stuff from other member owning W204 C63 AMGs?
Regards
Jay
Old May 29, 2018 | 02:26 PM
Savage-wp's Avatar
2014 Mercedes C63 AMG 507 Edition
Eurocharged sell a complete Flex Fuel package for the C63. They can source bigger injectors as well.
https://mbworld.org/forums/c63-amg-w...available.html
Old May 29, 2018 | 02:40 PM
2009 C63 AMG
After how many miles shall an injector be changed. I assume something around 50000 miles.
Old May 29, 2018 | 03:14 PM
Lupin's Avatar
C63
We have a group buy going on for the E85 kit. $1250 for the kit.
https://mbworld.org/forums/c63-amg-w...round-2-a.html
Old May 30, 2018 | 12:14 PM
Mark Manuel's Avatar
C63
Try this place for the injectors
https://www.fiveomotorsport.com/siemens-2599u550-fiat-550cc
By far the cheapest option for upgraded injectors.
It will require you to change connectors to uscar/ev6/ev14 which can be found using Google searches.
I have converted to e85 with upgraded injectors (660cc) but think I need to upgrade the fuel pump soon as I'm getting a low pressure pending fault code while on e85.
Old May 30, 2018 | 02:34 PM
2009 C63 AMG
Just curious. What mods are you running that required you to go for bigger injectors and now bigger fuel pump.
https://www.fiveomotorsport.com/siem...550-fiat-550cc
Old May 31, 2018 | 02:52 PM
C63
Decatted, EC V7, high flow filters.
Added the 660cc injectors just to make sure I'm not running lean.
I think when on e85 there's more of a fueling demand, hence why I think I need a higher flowing fuel pump. But more testing to be forsure.
Old May 31, 2018 | 05:00 PM
Sundown's Avatar
m156
I’m using these with e85. Work great.
Old May 31, 2018 | 10:29 PM
SactownP31's Avatar
C63 p31 coupe, Clk550 cab, M3 coupe, LS430, 750LI
Adaptors needed?
Old May 31, 2018 | 10:40 PM
Sundown's Avatar
m156
Ev1 female adapter to MLK male Ev1 is for the injector and the MLK is to connect to the harness
Yes adapters needed . EV1
Old May 31, 2018 | 10:54 PM
SactownP31's Avatar
Interesting, definately something to think about. Thanks for the quick reply.
Old Jun 2, 2018 | 07:41 PM
2009 C63 AMG
Thank you. This really helped.
Old Jun 5, 2018 | 08:24 PM
2009 C63 AMG
Question
Hey
Does this adapter looks good if I buy the same 590cc bosch injector you have?
https://www.ebay.com/itm/8pcs-EV1-Je...4AAOSwrhBZAbWs
JAy
Old Jul 18, 2018 | 10:48 PM
erlife's Avatar
2009 C63 AMG
Can you send me pictures and or describe how you modified the connections to work? I have ev1 injectors and stock mlk harness. I can not find info on how to make it work without splicing the harness itself. Looking for plug and play if possible.
Old Jul 18, 2018 | 11:40 PM
Doc Oc's Avatar
2013 c63 amg dev pack
http://www.finjector.com/verkkokaupp...m-p-722796-39/
This is what you're looking for. I think vrp also sells a set of harnesses.
