transmission cooler c63 w204
hello everyone, im new in here and i want to ask if there is any good transmission coolers for w204 c63 09. I drive my car under heavy heat conditions as its my daily driver but i also don't want to lose the efficiency of the transmission.
need help and if someone did that upgrade please give me feedback.
thanks
thanks
thanks
thanks
As far as an actual cooler goes, the only setup I've seen is mentioned by member cracklin:
https://mbworld.org/forums/c63-amg-w...ml#post7433046
I’m pretty sure facelift cars have a bigger trans cooler. I think DADS C63 retrofitted that. Not sure what’s required to do that (different lines perhaps?) but that could be an easy option along with the weistec pan.
do you think there is noticeable difference in performance when upgrading to weistec pan?
