C63 AMG (W204) 2008 - 2015
P0171 P0174 LEAN C63
Old Sep 11, 2018 | 03:50 PM
scrappykoko63's Avatar
c63
Replaced the Gasket, Bolts, PCV Valve. Still throwing up codes. Everytime i clear it the whole car starts shaking bugging out sometimes even dies unless i give it a rev. My question is what can it be for such a rough idle, it idles at 1k unless the air conditioner is on. Getting very poor mpg even in Comfort mode. This is my last straw with this car sadly. If i cant fix it im going to say my farewells with this car.
Old Sep 11, 2018 | 03:54 PM
chrisridebike8's Avatar
'10 C63
Maybe try O2 sensors. Make sure all the vacuum connections are installed properly since you disconnected them to take the intake mani off.
Old Sep 11, 2018 | 04:19 PM
skratch77's Avatar
2005 E55
Did you inspect the throttle bodies? The plate is know to crack and let air through it.
they sell metal plates on Ebay for 250 if it's broken or I have an OEM one for 300 if you want it. I also have 2 OEM throttle bodies if they are the problem
Old Sep 11, 2018 | 05:19 PM
c63
How can i check if its the throttle body???
Old Sep 11, 2018 | 05:21 PM
c63
how do i check if its the throttle body
Old Sep 11, 2018 | 06:04 PM
skratch77's Avatar
2005 E55
Unfortunately you need to take the whole thing apart again.
the oil eats up the tb plate and cracks it
Old Sep 11, 2018 | 06:42 PM
c63
there is absolutely no shot spark plugs can throw these codes is there
Old Sep 11, 2018 | 06:44 PM
skratch77's Avatar
2005 E55
I would change plugs and 02 sensors first
Old Sep 11, 2018 | 07:12 PM
c63
will do, o2 sensors are working fine i was thinking spark plugs fouled out
Old Oct 24, 2018 | 01:47 PM
c63
mercedes said it ended up being the o2 sensors would that be causing the loss of power aswell???
Old Oct 25, 2018 | 10:07 AM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
Yes, big time!! Since the ECU uses it to control the mixture.
Old Oct 26, 2018 | 02:19 PM
c63
i just dont get why at idle itd rev up to 1000 and then when i put my ac on itd idle normal
Old Oct 26, 2018 | 03:42 PM
skratch77's Avatar
2005 E55
If you need oem amg throttle bodies and the oem plate that can crack and leak I have a set. I upgraded to 82mm throttle bodies with new bigger plate.
