C63 AMG (W204) 2008 - 2015
Rotten egg smell after 2nd CAT delete
Old Oct 8, 2018 | 06:30 AM
Gammaz113's Avatar
C63
Hi All,
I deleted my secondary CAT today and replaced with straight pipe at my local exhaust shop. I noticed rotten egg smell inside cabin after hard acceleration and race start. Under normal driving is fine. Is it normal to get rotten egg smell after hard acceleration without 2nd CAT?
Old Oct 8, 2018 | 08:18 AM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
I never had any smells at all with secondary cat delete - it would be normal if you had no cats - do you still have the primary cats? Do you have a tune?
Old Oct 8, 2018 | 09:14 AM
Ludedude's Avatar
2014 C63 Coupe
Do you have a leak?
Old Oct 8, 2018 | 07:42 PM
Gammaz113's Avatar
C63
No tune. Still have primary cats. Only under hard acceleration or race start. I will bring it back to the shop to check.
Old Oct 8, 2018 | 07:43 PM
Gammaz113's Avatar
C63
Originally Posted by Ludedude
Do you have a leak?
​​​​​What are the sign and symptoms of a leak near 2nd cat area?
Old Oct 8, 2018 | 09:06 PM
curt.r's Avatar
2013 P31 C63 Sedan
Old Oct 8, 2018 | 09:16 PM
SuckaGDog's Avatar
C63 AMG Black Series
What year and how many miles on the car? It's normal for that egg smell to occur after hard acceleration or pulls. It's only a problem if it smells constantly like that. Which would mean the primary cats are failing.
The sole purpose of the secondary cats is to filter what the primaries left behind. I'm sure it removed a majority of the smell before.
Old Oct 8, 2018 | 10:04 PM
Doc Oc's Avatar
2013 c63 amg dev pack
Put the car on a rack or stands and run your hands just above and all around the welds with the car running. You'll feel the leak if there is one. I do this type of work daily and it's very hard to get a clean weld at the top of the pipes (assuming they didn't take the pipes off to do the work) due to space restrictions so if there is a leak it's probably at the top of one of the welds.
Old Oct 8, 2018 | 10:08 PM
bhamg's Avatar
C63 AMG
I'm fully catted and get the rotten egg smell after hard acceleration. It comes with the territory.
Old Oct 10, 2018 | 01:22 PM
AhhMyyGawd's Avatar
2015 C63 AMG Coupe
its normal, should go away after a few more hard accelerations. Its the heat expansion or something that will cause that smell. Give it a few days, info is from Mike
Old Oct 10, 2018 | 02:31 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
You need to let your primary cats heat up more before beating on it.
Old Oct 10, 2018 | 04:09 PM
BalanBro's Avatar
2012 C63 P31 Sedan
Mine does it too under heavy load conditions only. Good to see it's relatively common, although I still find it strange. I've driven many different cars from N/A to forced induction and various flavors of OEM cats, high flow cats and test pipes, and I've never had this sulfur odor before. For the folks that do have this smell, are you running a tune (I have EC V7)? I'm thinking WOT AFRs may be a factor.
Old Oct 11, 2018 | 12:49 AM
Gammaz113's Avatar
C63
My rotten egg smell for somehow has disappeared even under short burst of hard acceleration and running at highway. I am taking my beast out in the track in a few weeks time and will see how it goes.
I am really impressed with 2nd cat delete! it brings the beast alive! loving the AMG Music
Old Oct 11, 2018 | 04:06 PM
sventastic82's Avatar
2010 C63 AMG RIP. 2021 Toyota Tacoma TRD Off Road, 2013 C63 coupe
The rotter egg smell is usually caused by worn cam shafts. I would ask a euro car specialist to fix that.
