C63 AMG (W204) 2008 - 2015
1,124 WHP C63
Old Oct 26, 2018 | 09:48 PM
marioflex's Avatar
c63 AMG
1,124 WHP C63
After a break finally the car is better and stronger.
weistec stage 3 and v2 transmission. Build engine and tune by Steve Atneyel.
It is a sleve block with customs piston and rods. As said before car is supercharged and use nitrous.
Thanks to my friends Alex Javier Rivera and Fernando Rivera for their hard work.
Facebook Post
Old Oct 26, 2018 | 10:23 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Old Oct 26, 2018 | 10:29 PM
chrisridebike8's Avatar
'10 C63
Whoa! Is this on pump gas or...? How does the trans handle that?!
Old Oct 27, 2018 | 09:31 AM
Savage-wp's Avatar
2014 Mercedes C63 AMG 507 Edition
Damn, that is a bucketload of power. Must be an animal to drive.
Old Oct 27, 2018 | 12:41 PM
Peterc63's Avatar
C63
Old Oct 27, 2018 | 12:52 PM
Celicasaur's Avatar
W212 - E63 AMG
Wowwwwwwser
What tranny mods??
And how much of a 'small shot of nitrous' are we talking here??
Old Oct 27, 2018 | 01:57 PM
ecohen2's Avatar
Tire shredder...
Old Oct 27, 2018 | 02:09 PM
marioflex's Avatar
c63 AMG
Transmission is a regular Weistec V2. More clutches with better materials. To keep oil temp down we incorporate an oil cooler that works with the cold water from the ice tank. So far is holding great. Lets see how it works at the track.
About how much nitrous it is not a "small amount" that's an inside joke. I did not make the video.
Old Oct 27, 2018 | 02:14 PM
Mort's Avatar
Awesome, good luck at the track!
Do you drive this car on the street?
Old Oct 27, 2018 | 02:43 PM
marioflex's Avatar
c63 AMG
Not much, streets in Puerto Rico are in very bad shape specially after the huracane. Also the car now has a full roll cage sol is not that safe without a helmet.
Old Oct 27, 2018 | 04:20 PM
Peterc63's Avatar
C63
lol not safe with a helmet either... 😂
Old Oct 27, 2018 | 05:33 PM
mr747's Avatar
c63
Awesome news mate
i can imagine the smile on your face right now
Old Oct 27, 2018 | 08:50 PM
marioflex's Avatar
c63 AMG
Thanks Brad, definitely very happy.Looking forward to see how the car react at the track, Specially the transmission.
Old Oct 29, 2018 | 03:21 PM
Kriston's Avatar
C63 AMG
WOW! That is a crap load of power. Without the Nitrous what kind of numbers is the car making?
Old Oct 29, 2018 | 04:50 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
this is with stock block and headgasket?
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Oct 29, 2018 | 07:39 PM
marioflex's Avatar
c63 AMG
The power without nitrous is in the mid 7xx.
Old Oct 29, 2018 | 07:45 PM
marioflex's Avatar
c63 AMG
It is a sleeved block with custom pistons and rods. Head gaskets are stock, they work fine.
Old Oct 29, 2018 | 07:49 PM
marioflex's Avatar
c63 AMG
Sorry!! with APR head studs
Old Oct 30, 2018 | 01:01 AM
RNS-11Z's Avatar
09 C63
Mario, are you using the 60mm pulley? Have you looked at 57 or 55mm pulley?
Old Oct 30, 2018 | 08:24 AM
marioflex's Avatar
c63 AMG
55 mm. I want to try a 57 to see the difference. I really think the 3L is already max out and it just generates more heat with smaller pulley. BTW sadly I don't get any HP increase with my gen 3 conversion blower. Steve play with the tune at the dyno but it is what it is. To get more power it needs a bigger blower a turbo or nitrous.
Old Oct 30, 2018 | 09:04 AM
RNS-11Z's Avatar
09 C63
Did you custom make the 55mm pulley? How much boost are you making?
Thanks for the prompt reply too.
h.
Old Oct 30, 2018 | 11:24 AM
marioflex's Avatar
c63 AMG
No, Weistec sent it with my blower when i first bought it long time ago.
Old Oct 30, 2018 | 11:34 AM
marioflex's Avatar
c63 AMG
It's weird because with generation 3 blower I got 18 pounds of boost and with older blower 14, but not any gain in whp. Again not the same dyno because the other doesn't exist anymore, but I don't think that makes so much difference.
Old Oct 30, 2018 | 06:52 PM
RNS-11Z's Avatar
09 C63
Ok thank you. My plan is to run 18psi with the 3lt charger as well. I have ported heads and 2in header pipes, so I’m curious to see how much boost I’ll make with the 60mm first.
thanks for your help
Old Oct 30, 2018 | 08:32 PM
marioflex's Avatar
c63 AMG
I have the MBH Tri Y headers and CNC ported heads. I don't think you will get 18 psi with a 60mm but lets see. With my 55mm I use to get 14.
