PSA Quickjack 5000
https://www.costco.com/QuickJack-5,0...100460313.html
But did anyone that previously purchase ever post any pics/notes on how it worked out with their car? That would be helpful.
I do have a leak at the hydraulic fluid reservoir that I'm trying to get addressed. It's still usable, but I'm getting a few drips on my floor during storage which is quite annoying. The newer models have a different tank design than mine, so this may not be an issue anymore.
Not that I do not trust Quick Jack, I would never allow stand alone use of Quick Jack without back up safety jack at rear and front of car
Below is my driver removing under carriage shield for inspection of under carriage conditions.
I also add some add'l safety w/jack stand under the plate and ramps under the wheels. You can also reach each side of the 'lock point' at slightly different times and 'might' have to manually raise the 'drop catch' (or whatever its called), so be aware of that. I recall reading something long ago recommending using this in only one position (the front of the car one way, etc.) and have only needed to raise the MB to the 1st position, but need to research a bit more before I'm comfortable regarding potential 'nose heavy' cars, and all the other stuff I just mentioned before taking it to the highest setting and getting under it.
Bottom line, if someone as cautious/paranoid
as me can use it, anyone with any decent mechanical skills shouldn't have a problem.
https://www.reverselogic.us/phone/me..._jack_pad.html
The platform reaches too far and can be too long for a car, where it either hits the front or rear suspension?
We have an Abarth in the household as well, really short wheel base.
