I hit a deer: Pre-Facelift to Facelift Conversion
Well - here is the finished product.
There are only (2) things you need to know about this conversion, set in stone once in for all:
1) When doing a PFL to FL conversion, you do not need any mechanical hardware. This is a direct bolt on from hood, bumper, and grille. I went OEM everything with DEPO replica headlights.
2) Running lights and blinkers do NOT work - it's a different PIN conversion. You will need to purchase these from Germany, or pay someone a large amount of money and patience to rewire using a diagram:
http://www.kabeldaviko.de/product_in...enon-mopf.html
http://www.kabeldaviko.de/product_in...b-12-2009.html
BLKROKT (02-04-2022)
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
Looks good man! Really good! You mentioned that there is some extra work that goes in to getting the DRLs and blinkers to work? I assume you got that sorted?
If you have the wire code to what wire goes where, it really shouldn't be too bad......Just get really good connectors and use really good felt auto tape to protect the wires like OEM.
Looks good though!! I still want PFL front end on my FL car......LOL
It would take 3-4 hours to route the wires correctly and splice I think...Way cheaper to buy this $170 connector set.
So stay tuned I'll have a final update on blinkers and running lights once I know for sure.
Glad to see the FL Hood worked out
Looks great bud!!
Plz stay safe
Looks great bud!!
Plz stay safe
#35
Yeah watched it a few times I thought it was still twitching a bit. I know deers can take quite a hit from cars so wanted to see what happened.
When you got out of your car was the thing just straight up dead? That must have been shocking.
#36
When it's head slumps back while sliding is when it died. No twitching. It was straight up not moving.
#37
Thanks man! The hood sits higher than the pre-facelift, I like it a lot more - its aggressive. We're doing a run to Ballast Point on Saturday. Meeting at "The Point" in El Segundo for Cars and Coffee. From there, we will leave at 9:20 to Long Beach where we will meet up with a large group of AMGs. You're welcome to come!
MBNRG (02-05-2019)
#39
https://www.ebay.com/itm/New-Hood-Gr...53.m2749.l2649Grille is from eBay , doesn't come with the hood trim. It appears to be OEM quality, better than plastic ones I've gotten.
I had it professional painted gloss black.
#41
Ok we've reached an issue:
The two connectors from Germany, which hooked up fine. It allowed for the blinkers to function.
However, the running lights won't stay on. They fire up, flicker, then go out. Our Mercedes electrical coder guy has never seen this before. My guess is that perhaps there is too much power going to the LEDs which causes them to short out. We need some sort of bypass. My thought is to buy a 2012+ headlight control switch, and take out the older one.
Any thoughts on this? There is little to no information out there, besides "it requires coding work" that no one knows about.
#43
2016 GTs, 2014 C63 AMG and 2014 C350 Sport (wife's car, she thinks it's an AMG - shhhhhh)
Hi SM, while you are answering questions, where did you get your rear diffuser? It doesn't look stock to me unless the fins were bigger on pre-FL.
#44
#46
It does fit - scroll up to my pre-accident photos you can see I had one on. The plastic is already black and they paint black, so you don't notice chips. I am actually having more issues with the OEM one that I got painted b/c it's got chrome underneath.
Sincity (03-13-2019)
#47
Did you ever ever get it all the conversion issues sorted out?
#48
