Rear caliper R&R
Can an anyone share how they have accomplished this feat? I tried disconnecting the top of the sway bar end link and that did not create enough room. Any ideas?
Can you put a 1" universal joint extension with a shallow socket on it?
Can you use a very long 1" extension and reach from the other side of the car ?
You CAN use an offset closed wrench with a 1" drive hole in it and put together some very simple math and adjust the torque wrench to a smaller torque.
If it's with locktite, I would buy their product from the dealer, it's not going to be a fortune and you are guaranteed not to mess the torque.
It's impossible to be 100% sure what the Affalterbach boys spice their threadlocker up with. As such, the friction properties may be something that they figured out in their prescribed torque number.
some better info here when I asked same:
https://mbworld.org/forums/c63-amg-w...ml#post7605423
https://mbworld.org/forums/c63-amg-w...ml#post7473192
