C63 AMG (W204) 2008 - 2015
Adaptive headlights not working???
Old Jan 19, 2019 | 11:18 AM
Uneazy's Avatar
2009 Mercedes C63 AMG 2002 BMW M3
Long story short I had to replace a ballast on my driver side headlight..both lights turn on but neither one of the headlights are having any kind of movement like they used to plain out when turned on now nothing at all....the lght I replaced is pointing straight at least while the other seems to be staring at the ground I don't think both motors are toast is there a fuse or something that controls the adaptive hid's? Been searching online and here on the forums to no avail...
Old Jan 20, 2019 | 09:24 AM
Vladds's Avatar
2010 C63 2019 GLA45
There could be a teach in procedure performed through the factory software, Xentry.
Old Apr 15, 2022 | 06:44 PM
J0HN_R1's Avatar
'19 4runner TRD / '12 C63 AMG
Having a similar issue after replacing a bulb, the actual housing the bulb is in moved while taking it out.
Now it doesn't move around with the steering wheel, doesn't do the "cycle" at start-up, and isn't centered either...
Did you fix yours, or did you take it to the dealership ?
Old Apr 15, 2022 | 07:19 PM
Uneazy's Avatar
I adjusted them manually so they're pointing straight they still don't move though
