C63 AMG (W204) 2008 - 2015
Thermostat DIY?
Old Jan 30, 2019 | 12:01 PM
Drift1492's Avatar
Infiniti
Thermostat DIY?
Thermostat is definitely stuck open. Have the thermostat but am short on time. I've ran a handful of searches to figure out what all is involved. Found one guy who said it took his shop 10 minutes and one who said the entire front of the engine had to come off. Does anyone know of a DIY? If it takes a shop 10 minutes, it'll take me an hour. If the whole front of engine has to come off, who knows. Thoughts?
Old Jan 30, 2019 | 12:03 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Really shouldn't be that hard.
Remember to get new antifreeze.
Old Jan 30, 2019 | 12:29 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
5min job, it’s right there
Old Jan 30, 2019 | 12:41 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
1 MILLION dollars says you can't do it in 5min...
Old Jan 30, 2019 | 01:08 PM
Adi-Benz's Avatar
Well, maybe not 5 but less than an hour for sure,
It is literally right there
Old Jan 30, 2019 | 01:27 PM
Garret Ohm's Avatar
2016 VW Golf R
I’m in the same boat. Anyone have a video tutorial out there for c63?
Old Jan 30, 2019 | 02:01 PM
BLKROKT's Avatar
I’ll take that bet. Let me do it on your car and we’ll record it. It’ll be fun.
Old Jan 30, 2019 | 03:32 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Old Jan 30, 2019 | 07:09 PM
Edddiec63's Avatar
09 c63
I just did the thermostat on mine prolly will take you 20 min tops
Old Jan 30, 2019 | 10:43 PM
Funkwagen's Avatar
2009 C63 AMG, 2010 C250 4Matic Sport
Pelican parts DIY guide
Did mine about a year ago at home in my parking spot. Easy job for sure
Old Jan 31, 2019 | 07:10 AM
Drift1492's Avatar
Infiniti
I've seen that DIY buts it isn't a m156.
Old Jan 31, 2019 | 11:26 AM
Adi-Benz's Avatar
Pretty damn close man
Have you even located the thermostat
Old Jan 31, 2019 | 03:28 PM
Funkwagen's Avatar
you're right, I actually thought I was in the regular w204 forum
Old Jan 31, 2019 | 10:30 PM
Drift1492's Avatar
Infiniti
Yes. A lot of stuff in the way on the m156. Can't tell what needs to move, if anything. Just looking for some direction before diving in.
Old Jan 31, 2019 | 11:14 PM
SGM330's Avatar
10' C63
It's straight forward. Mine was stuck open as well.
1. Remove front engine cover that has Mercedes emblem
2. Disconnected the two rubber hoses that go around the power steering reservoir.
3. Unbolt power steering reservoir and move to the side.
4. Remove both coolant hoses that connect, there's just a clip that needs to be pulled and the hoses wiggle off.
5. Then remove and re-install the new thermostat.
I did mine with no DIY. Once you remove the power steering reservoir you'll figure it out. There's no surprises on this job.
Old Feb 21, 2019 | 09:11 PM
djr48312's Avatar
2009 c63
Where is the engine coolant tempurature sensor on these cars?
Old Feb 22, 2019 | 07:39 AM
Drift1492's Avatar
Infiniti
Thanks everyone for chiming in. Knocked this out in about an hour last weekend. Much easier than I expected.
Old Feb 22, 2019 | 08:53 AM
Adi-Benz's Avatar
Glad it went well 👌
Old Feb 22, 2019 | 10:56 AM
djr48312's Avatar
2009 c63
good job. Is the engine coolant temperature sensor near the thermostat housing?
Old Jun 4, 2020 | 07:42 PM
tasteofpower's Avatar
2011 C63 AMG
im stuck on #3. lool. i only saw 1 screw...which i loosened. there another you could point me to?
Old Jun 5, 2020 | 03:07 AM
curt.r's Avatar
2013 P31 C63 Sedan
I know it's not a C63 but I hope this helps.
Old Sep 17, 2020 | 06:54 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I'm assuming this is another temp sensor?
Possibly why the dash reading is different than the OBDII reading? All the temps below are recorded at roughly the same time. The upper rad hose temp was more inline with the dash temp. The expansion tank eventually caught up with the rad hose temp the longer I let it idle.
I would notice as it idled longer the rad fan would kick on slow speed and the OBDII coolant temp would fluctuate around the 96C mark with the dash temp stable at 92C. Possibly time for a new thermostat.
Old Sep 17, 2020 | 09:04 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Confirmed the t-stat sensor is for the dash (unless there's another one somewhere else). That sensor up higher must be what OBDII reports for coolant temp. When it's unplugged the rad fan comes on full beans. Probably threw a code as well I will check what OBDII says with it unplugged tomorrow.
