Which OEM wheels are prone to cracking?
The cause of rims cracking in street applications is almost always the rim hitting a hard object, usually in the form of a pothole on the pavement. Whether the rim is stock or aftermarket, at what speed the vehicle hit the pothole, how inflated the tires were and how sharp the pothole edges were and their precise geometry relative to the rim lips all play in role, but they were all a result of a hit. Nothing else. Are some rims stronger than others? Absolutely... but that simply means that stronger rims are able to absorb an impact of a certain force without (obvious) damage whereas weaker rims cannot and they crack or bend.
In racing applications rims can also crack due to fatigue, but the lateral forces that they are constantly exposed to in that environment are simply not achievable on public roads and/or with street tires.
As a VERY GENERAL rule of thumb, on most vehicles I've seen that are offered with different size wheels tires, for every 1" of increase in wheel diameter (assuming that the overall tire diameter / circumference stays the same) the pressure needs to go up by about 4 psi.
I'll clarify and say with a bigger rim (smaller sidewall on a tire) you need to stay on top of your tires air pressure more-so then if you had a taller sidewall
