Removing Secondary Air System
There’s really zero benefit in deleting it unless yours is broken or you want to save 3lbs of weight. It’s only active at startup, otherwise off. You’ll get codes if you remove it, and may not pass emissions. Just leave it alone IMO.
There only appears to be one hose leading out of the pump. Instead of making EGR blockoff plates for the intake manifold - never mind figuring out what to do with the heat shielded lines going down to the exhaust somewhere... Would it be possible to just remove the pump and block off the one hose that leads up to the EGR valves? What could happen?
I’m thinking to clamp a metal plug in the line, and if the pump is off.... nothing will happen? The EGR valves are vacuum controlled I believe, but they’re not going to push air back down the hose and blow out the plug will they?
Someone please educate me here, thanks.
Next question. Does anyone know if the SAI can be coded out easily? I really don’t need a CEL or another emissions monitor showing as “not ready”.
2. Go to Control Units
3. Go to Drive
4. Go to MESFI 2.8
5. Go to Development Data
6. Go to Control Unit Adaptations
7. Go to Control Unit Adaptations(Variant Coding)
8. Go to Implizite Kodierung ME281 AMG C6-Stand
For EGR scroll down to 0176 and change Diagnose ein to Diagnose aus
For Secondary Air Injection scroll down to 0178 and change Diagnose ein Diagnose aus
For Post Cat 02 sensors scroll down to 0182 and change Diagnose ein Diagnose aus
UNLOCK ME 2,8 SFI
control unit groups
drive
ME 2,8 SFI
development data
actuations
complete index of actuations
steuergerät entriegeln -> confirm (In English: ECU unlock for programming))
then apply variant coding while engine is still running.
So before I could see programmed options I had to use some setting to read them , after was able to program while engine running.
nevermind that was simple
https://www.vrpspeed.com/product/vrpegr/
3. Go to Drive
4. Go to MESFI 2.8
UNLOCK ME 2,8 SFI
control unit groups
drive
ME 2,8 SFI
development data
actuations
