C63 AMG (W204) 2008 - 2015
2012 Mercedes C250 Coupe 1.8l turbo - oil in spark plug wells
Old Apr 8, 2019 | 07:03 PM
Richard Koop's Avatar
2012 Mercedes C250 1.8L turbo
Argh! Nothing is simple on my wife's car... It has about 100,000km. I went to change the spark plugs and there was about an inch of oil pooled in each of the cylinders. After sucking/cleaning it out it looked like this.
Not sure where it's coming from. I did notice the gasket/seal on the oil filler cap seemed deformed/broken.
Could this be the reason for the oil in the spark plug wells? I sure hope it's not a leaking valve cover gasket because that's probably a pain to change. Or maybe the PO doing careless oil changes and spilling oil? Strange didn't smell any burning oil smell.
Richard
Old Apr 8, 2019 | 07:20 PM
BenzoPro's Avatar
2016 G550
Richard
I'd suggest hope for the best clean it up real good drive for a couple of weeks and recheck if it wet again then it's time to replace your valve cover gasket sorry but let's hope for the best, if you do need a new gasket check out this place a just found online a few weeks back they have O.E. parts but much cheaper then the dealer. www.mbpartsprime.com you'll be happy they have everything the dealer has but lot's cheaper.
Old Aug 24, 2019 | 08:42 AM
azblk's Avatar
2013 C250 SPORT, 2014 WRX STI SEDAN, 2017 E300 4MATIC
Richard
There is rubber gaskets around each spark plug wells and the valve cover. They get old and let in the oil into the wells.
Old Aug 24, 2019 | 09:53 AM
Thanks. I've got the valve cover off to replace camshaft adjusters now anyways so going to replace all the gaskets.
Richard
Old Aug 25, 2019 | 07:26 AM
New camshaft adjusters installed. The arrows between the camshaft adjusters (the ones that point to each other) are perfectly aligned. Hopefully that's a good sign. Also my kit came with the top plastic guide (it sits at the top between the adjuster wheels). The current one I'm able to wiggle back and forth. Is that normal or should I replace?
Also there are 2 plastic guides at the top of the cover near the camshaft adjusters and the tab are broken. These didn't come with my kit.
I'm hoping that those are more for alignment and they will seat in the camshaft cover and be held tight. Or I'll have to try to order those somewhere.
Timing chain guide rail
Richard
Old Aug 25, 2019 | 10:20 AM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
This thread is in the wrong forum FYI, this is the C63 forum.
Old Aug 25, 2019 | 11:37 AM
go team's Avatar
2012 C63, GL63, 1989 300CE
That’s a funny looking M156.
Old Oct 28, 2019 | 05:10 PM
Suleil's Avatar
2012 mercedes c250
I have the exact same problem. How you clean the cylinder area .? I just put the spark new idk how I can that area
Old Dec 31, 2022 | 04:50 PM
doc.catatonic's Avatar
W204 and X166
Did this resolve your problem with oil on spark plugs?
