C63 AMG (W204) 2008 - 2015
Girodisc Replacement Rotor Upgrade - W204 AMG
Old Apr 17, 2019 | 07:37 PM
AutoTalent's Avatar
SPONSOR
G55
Click here to purchase front rotors!
Click here to purchase rear rotors!
The Girodisc system is a direct replacement for the OE disc. No modifications are necessary. The disc will bolt directly to the car and work with OE calipers perfectly. By upgrading your brakes with lightweight high performance replacements as opposed to a big brake kit, your factory bias is maintained as well as your ABS efficiency. The Girodisc front rotors are approx 23.6lbs vs. 34.5lbs for the stock units. This reduction in rotational and unsprung weight allows for quicker acceleration and suspension response.
The central hat section of our rotor is made from strictly U.S. sourced 6061-T6 aircraft specification aluminum. The disc is made from our own proprietary cast iron, poured in the USA and machined from start to finish in house at Girodisc. The rotor utilizes a curved vane design, developed in racing to act as a centrifugal pump to force cooling air through the disc.
The rotor and hat have a floating mount system, which utilizes 10 high strength alloy steel drive pins, manufactured by Girodisc in the USA to our own specifications and cadmium plated for a long lasting corrosion resistance. These pins take the load from braking actions while maintaining the axial and radial float between the hat and disc. The pins are secured by grade classs 12.9 screws with hardened washers. In order to keep the rotors from making noise when cold, the pins are mounted with anti-noise spring washers on the rotor side which allow the rotor to grow with heat expansion but eliminate the rattle and noise associated with floating rotors. This float also allows the rotor to self center between the pads.
Once the Girodisc system is in place, simply replace the cast iron rotor when needed.
Sold/priced in pairs
Girodisc Replacement Rotors (W204 C63 AMG)
How to Place Your Order:
Phone Domestic: (855) 973-2757 X 104
Phone International: (310) 231-7800 X 104
E-mail: Golan@AutoTalent.com
Website: www.AutoTalent.com
Payment:
Installations:
Feel free to visit us at our 20,000 square feet facility in Los Angeles, CA.
We install everything we sell.
19143 s. Hamilton Ave
Gardena CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
Old Apr 17, 2019 | 08:50 PM
Crya's Avatar
2009 C63 P30
Just curious if you guys can price match on these? I know $1200 is MAP etc so if you can I’d be more inclined to give my money to a forum sponsor etc.
Old Apr 17, 2019 | 08:51 PM
AutoTalent's Avatar
SPONSOR
G55
I will beat whatever you have
PM or email me to make it happen!
Old Apr 17, 2019 | 11:51 PM
chrisridebike8's Avatar
'10 C63
Girodisc front rotors do not weigh 14 lbs. You might want to QA your ad and make sure it’s for a W204 C63. Should be 35 and 24 lbs vice 22 and 14
Old Apr 18, 2019 | 01:27 PM
AutoTalent's Avatar
SPONSOR
G55
We copied the description directly from the site yesterday and looks like it was off. Thanks for catching that!
23.6lbs is the weight of the front rotor compared to 34.5lbs stock.
Old May 16, 2019 | 08:33 PM
AutoTalent's Avatar
SPONSOR
G55
Bump!
Old Jun 4, 2019 | 08:31 PM
AutoTalent's Avatar
SPONSOR
G55
Bump!
Old Jul 2, 2019 | 08:36 PM
AutoTalent's Avatar
SPONSOR
G55
10% off 4th of July special!
Old Jul 23, 2019 | 02:54 PM
AutoTalent's Avatar
SPONSOR
G55
Bump!
Old Aug 5, 2019 | 08:25 PM
AutoTalent's Avatar
SPONSOR
G55
Bump!
Old Sep 9, 2019 | 11:05 AM
AutoTalent's Avatar
SPONSOR
G55
Bump! We are running specials on Girodisc rotors for all of September. Please contact us if interested!
Old Sep 12, 2019 | 05:37 PM
AutoTalent's Avatar
SPONSOR
G55
Bump!
Old Sep 13, 2019 | 01:10 PM
AutoTalent's Avatar
SPONSOR
G55
Bump!
Old Nov 11, 2019 | 10:29 AM
AutoTalent's Avatar
SPONSOR
G55
Bump!
Old Nov 11, 2019 | 11:32 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
You need to get Girodisc to offer a size upgrade kit. Either make an in-house caliper bracket like they do for the 308 or find someone like Stasis that makes them for the S4.
Old Nov 11, 2019 | 12:45 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Are these made in BS-spec sizes of 390/360? If yes, I’m interested in a set....
Old Nov 11, 2019 | 01:07 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Are the SLS rotor dimensions the same?
Old Nov 11, 2019 | 02:19 PM
BLKROKT's Avatar
SLS is 402/360 I believe
Old Nov 11, 2019 | 02:38 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
390/360 --> https://www.girodisc.com/Rotors_c_1278.html
Just not sure if they're the same.
Old Nov 11, 2019 | 09:56 PM
AutoTalent's Avatar
SPONSOR
G55
I will ask and let you know tomorrow!
Old Nov 15, 2019 | 09:30 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
They do have BS sizes just as an FYI. Not on their website yet.
Old Dec 2, 2019 | 02:56 PM
AutoTalent's Avatar
SPONSOR
G55
Bump!
Old Dec 3, 2019 | 08:54 AM
harrislee1303's Avatar
2012 C63 BS
Hi Golan,
Can you send me a quote for the rotors shipped to CA 94066 for the Black Series?
Old Dec 3, 2019 | 06:17 PM
mr747's Avatar
c63
Hey man ive sent you a couple of emails from DYne PErformance but you havernt responded
Old Dec 13, 2019 | 02:50 PM
AutoTalent's Avatar
SPONSOR
G55
Bump!
