Breaking traction from stationary
Hey ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
ive had my 2010 saloon for about 6 months now, and I’m genuinely smitten with it.
One thing that just seems odd is my car’s apparent traction from a standing start, it seems ‘too good’.
If if I turn off the ESP, put it in S, and nail the gas pedal it will squeal and spin a little, but generally it just hooks up and go’s - in some ways it’s a perfect launch 🚀
I probably wouldn’t question it but I read a lot about people doing similar things and it resulting in uncontrollable wheel spin without them rolling in the pedal. So it seems odd my car acts so differently.
I’ve reset the ECU and TCU and that seems to have helped slightly, it certainly holds gears longer. And once up and moving the car pulls really well...
does anyone else ‘suffer’ 😂 from extreme grip?!
Cheers!
james
Cheers!
james
James_ (04-30-2019)
Yeah I’ve definitely had it turned off, I think. On my 2010 model it seems to have 3 settings;
1. All aids on
2. sport handling with ESP on
3. ESP off (like you mention, by holding it for 5 secs or so)
maybe it’s because the tyres have only done 1k or so.
but yeah I hear you about manual, that will be what I try next
1. All aids on
2016 GTs, 2014 C63 AMG and 2014 C350 Sport (wife's car, she thinks it's an AMG - shhhhhh)
I have the same issue... gotta use manual b/c even in sport mode it shifts into 2nd early and allows the tires to grab hold.
I’ll run a few more experiments when I get a chance 🤓
You need to get on it so the computer learns you driving behavior. Drive it like you stole it and you won’t have a problem with transmission shifting early in from the 1 2 shift
resetting the ECU/TCU more frequently is a viable option though, when I did that it was noticeably more up for it
Burnout Level: UNLOCKED
Well, I gave holding the brakes lightly before planting it a chance today - and I certainly got the drama I was lacking ![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
Interestingly this was just in S, rather than manual, and obv with the EPS off.
I do need to work on my modulation a little though, as coming off the brakes slowly the car was starting to snake a little too much for comfort, all good fun though.
JeffACM (05-01-2019)
